26-04-2007, 02:01 AM | #1 | ||
How much boost can be put into a stock XR6 motor before having to change the computer and injectors?
26-04-2007, 08:28 AM | #2 | ||
The one and only
10psi.
What are your plan's?
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
26-04-2007, 08:56 PM | #3 | ||
I was thinking of making my own set up using one of the older roots type Toyota superchargers. They're a positive displacement blower and displace 1400cc. The way I've worked it out, the blower should provide 40% more air than N/A. What that equates to in boost I don't know, and I may have worked it out wrong.
26-04-2007, 09:16 PM | #4 | ||
ORSM FORD CRUSIERS
I thought it was 9psi before the map decides to give in... make sure you get a 12:1 rise of rate fuel reg and a pump as well cause it will lean out for sure evan @9psi.
BLUEPOWER RACING DEVELOPMENTS Strive for perfection in everything we do. Take the best that exists and make it better. When it does not exist, design it. Accept nothing nearly right or good enough. -[BLKPHN] (VIC) PLATES FOR SALE $495.00-
26-04-2007, 09:17 PM | #5 | |||
Tuned @ Pitlane Frankston
Or do you mean 10psi with some form of fuel enhancement? such as a rising rate regulator?
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
26-04-2007, 09:21 PM | #6 | |||
I know its hard to compare a 4.0L with a poxy 3.8L Iron Boat Anchor. I guy I knew had a rebuilt 3.8L in a VK, with one of those superchargers you are talking about. My car with my old motor, cat back exhaust, manual, 3.9's would beat it. He eventually ripped it off.
Powered by Rollin Motorsport Turbo Barra ED 4L
26-04-2007, 09:22 PM | #7 | |||
ORSM FORD CRUSIERS
It will take 10psi before computer and injectors will be needed, but it will need reg and fuel pump instead these are a much cheaper items. i think this is what wayne is getting at.
27-04-2007, 08:42 AM | #8 | |||
The one and only
He will not be able to run 10PSI without some fuel management changes.
27-04-2007, 08:49 AM | #9 | |||
Last warning
doesn't mean it lasts that long though.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
27-04-2007, 11:09 AM | #10 | ||
I would say it depends on the fuel used more than anything and tuning as you all probably know mikes dyno white ea is a stock bottom end and he runs around the 21psi with stock internals but he doesnt use pump fuel and obviously runs aftermarket management.
As to how long it lasts he has done alot of runs on the limiter over tha past year and still has same bottom end. head gasket differant story..... |
28-04-2007, 09:51 AM | #11 | ||
Early E series run rich anyway. The bottom end of an I6 is very strong and you can get away with quite a bit from just changing the head.
