25-04-2007, 10:14 PM | #1 | ||
as most of you know i converted my ed from auto to man, i need a man comp with smart lock as my speedo and reverse lights are still out. And the car still idles funny.
My question is if anyone has succesfully fixed this prob before can you help me sort the prob out. |
25-04-2007, 10:20 PM | #2 | ||
Gunna girlie-man
how did you re-wire the reversing lights and the inhibitor switch?
Also did you switch the speedo gears?
WADE CAMS-- UNLEASH THE POWER!! <INSERT WITTY SIGNATURE HERE> Daily- 05' BA futura... work done. Cruiser- 85' VK berlina... more work done |
25-04-2007, 10:26 PM | #3 | ||
havent touched any of that as i didn't know how to i only do mechanical not electrical stuff.
om stuck when it comes to electrical. |
25-04-2007, 10:39 PM | #4 | ||
Gunna girlie-man
thats why the reversing lights and speedo arn't working. Speak to josh (efghia) he will tell you how to do it.
25-04-2007, 10:49 PM | #5 | ||
thanks mate.
26-04-2007, 09:45 PM | #6 | ||
I need some one in adelaide to have a look for me.
Please can someone help. Last edited by gngtho; 26-04-2007 at 09:46 PM. Reason: I shpelt it wrongs |
26-04-2007, 09:49 PM | #7 | ||
i have a spare manual ecu if ur interested
4.0Lturbo T56 AP Racing 520rwhp |
26-04-2007, 09:55 PM | #8 | ||
interested pm me with details.
26-04-2007, 09:57 PM | #9 | |||
26-04-2007, 10:55 PM | #10 | ||
Tuned @ Pitlane Frankston
Doing the reverse lights and speedo just requires some basic common sense.
Use your auto gearbox loom, chop it up, and get rid of the round plug and wires. Then take the white terminals off one end, leaving the black terminal at the engine side in tact. Then use a test light and figure out which wires are for the reverse lights/inhibitor switch/speedo, and plug em in. It's pretty easy to work out, just need a test light anc common sense. The ECU will go straight in no worries if you do the loom like i said.
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
26-04-2007, 11:19 PM | #11 | |||
27-04-2007, 08:37 PM | #12 | ||
Still havnt got one anyone with some help please realy need to fix this prob.
28-04-2007, 12:27 AM | #13 | ||
have you got a cam in your engine?
The idle problem could be a broken idle circuit in your manual ECU, or the ECU hasn't learnt properly, or the cam in the engine is causing the bad idle.
29-04-2007, 02:48 PM | #14 | ||
no cam.
