Old 11-04-2007, 05:22 PM   #1
$AUDude
99' AU Falcon Forte
$AUDude's Avatar
Default AU on the bench...
Hey Guys
Unfortunatly my AU1 won't start at the moment and I'm not really sure why. About a couple of weeks ago, it wouldn't start, didn't turnover or anything but we managed to jump start it and everything was fine, this happened again and was resolved the same way. Finally, it happened a third time yesterday, after a day of regular driving and now it will not jump start. All electrics in the car work so I'm not convinced it's a battery problem. Perhaps I need a new starter motor or alternator?
Any help would be apprieciated
Thanks :1syellow1
$AUDude is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2007, 05:41 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
interior light works ?
does it crank and just not start, got spark and fuel ?
Old 11-04-2007, 05:45 PM   #3
RG
Back to Le Frenchy
RG's Avatar
Just because the electrics work doesn't mean it's not the battery. It takes a lot more power to crank than to turn on a light.
Old 11-04-2007, 06:11 PM   #4
StealthAu
if you have power at the dash, just put it into diagnostics mode and check the volts, or better yet if you have a multimeter use it
Old 11-04-2007, 06:38 PM   #5
The Dok
The Dok's Avatar
Start with the earth terminal on the battery, remove it, clean it & the connector/s with sandpaper/wire brush, this is what the problem was with my mates AU & it had all the same symptoms as yours. It's a good place to begin!
Removed by laminge
The Dok is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2007, 06:56 PM   #6
$AUDude
99' AU Falcon Forte
$AUDude's Avatar
Thanks guys, I will pull out the multimeter and give it a clean tomorrow and see what happens
Wouldn't a jump start work if it was the battery?
Old 11-04-2007, 09:51 PM   #7
JC
JC's Avatar
Depends how you jump start it. If you put the positive on the positive, and the -ve from the donor car onto the -ve of the battery needing the jump, than that's not a good thing, and you may have fried a few important electrics. You need to jump the -ve from the donor battery to a good metal contact on the car (radiator support panel is usually OK). If you are doing this and it doesn't start, then I would clean the battery terminal contacts, as that could be your issue.
Ford Performance Club ACT
Old 12-04-2007, 12:06 PM   #8
LOWAU
___________
LOWAU's Avatar
When my battery died all the electrics were wroking properly except when I tried to start it, the alarm when on and all the symbols on the gauge started blinking. Also there was no crank.
Jump started it and drove it straight to claim a new battery from supercheap as it was just under warrently, now have a new battery and 2 more years of warrenty :sm_headba
How old is your current battery, if its your original ford one its is probly cactus by now.
LOWAU is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2007, 09:54 PM   #9
$AUDude
99' AU Falcon Forte
$AUDude's Avatar
Ok so the multimeter reads 12.4, so the battery should be okay? I tried cleaning the terminals and that didn't seem to work, I have also checked the fuses and they are fine. Because the electrics are ok, but there's no crank can I assume it's the starter motor or perhaps something else?
Thanks again!
Old 12-04-2007, 10:12 PM   #10
bodes-sh
change the multimeter to amps, it should be about 560, then hold it on there while someone cranks the motor, and see what it goes to
Old 12-04-2007, 10:22 PM   #11
AUXRVIII
Does the car have smartshield immobilization? Is there a symbol of a hand flashing fast in the instrument cluster?
You could also look at the starter relay under the bonnet, try swapping it with a cooling fan relay, you could also try using a jump wire to manually operate the starter.
Also could be a loose or broken starter solenoid wire (thinner wire on starter).
AUXRVIII is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2007, 09:39 AM   #12
LOWAU
___________
LOWAU's Avatar
Thanks again!
Is there another battery that you can borrow from a mate that you know is good that you can try? Then you can take your battery to supercheap or autobahn to get it tested properly(usually for free). You can't just test it with a volt meter unless its really bad and its showing below 12V. The amp test might work but i'm not sure.
I would try the battery first before look at other things as I had the same problem and I spent a good hour diagnosing before i found what it was.
Old 13-04-2007, 11:44 AM   #13
plzhelpmeiamnew
illiterate with cars
I had this exact problem last year with my au1, i also got good multimeter readings too. I replaced the battery and problem solved.
plzhelpmeiamnew is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2011, 09:42 PM   #14
LittleRoberts
Default Re: AU on the bench...
hey there all,
my problem is that i've tried to start my ford, and appeared to be a flat battery.. so i grabed another vehicle and {stupidly** attatched positive to positive and negative to negative on both batterys...
now the car wont start at all and the little 'smartsheild' hand stays on the dash???
can anyone help me try and work out whats gone wrong??
peace
LittleRoberts is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2011, 10:41 PM   #15
Boza
Boza's Avatar
mate get under there and whack the starter with a hammer a few times sounds like your starter isn't engaing.
Boza is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2011, 09:34 PM   #16
LittleRoberts
Originally Posted by LittleRoberts
hey there all,
peace
for the people that find this and have done the same thing.. {i'll be honest.. it wasn't me.. im not really that stupid... lol was my father!**
that said.. we ended up having to change the PCM{though he has a spare that he has already written off.. lol the car that is** so we swapped out the key barrel, the BEM and the PCM from the other one and it started first go..
so actually seamed to work out that he had 'fried' the PCM or it needs to be recoded with the BEM as they had forgotten how to talk to each other..{and rather then learning new key just swapped barrels aswell.. only having to recode W/remote**... that SMART SHEILD HAND never dissapeared...
after all that was changed, started again first go!!
though now have a completely different problem...{OR IS IT??????** the automatic{which we have just swapped as well with the other vehicle as its drive train is all ALOT younger...** is now stuck in 'LHM' or 'Limp Home Mode'.. meaning that the transmission is 'locked' in third gear..{NOTE ALSO MEANS YOU CANNOT GET UP HILLS!!!!!!!!!**{REVERSE!!!!!!!!!!!!!!!!!!!!!!**
though there is also some other dilemma...it currently is having a bit of a REVERSE throttle Experience so the harder your trying to push it the worse the performance actually is???!!!
at stand still wont get over 3000RPM?? when it does sounds like there is major problems like its coughing???
anyone have any ideas about the new issues that have developed???
ATM IT IS down at the local mechanics to get the 'codes' reset or 'flashed' to try and see what is actually wrong with it...
Peace
Old 27-06-2011, 09:53 PM   #17
roberts
Peace
negative on the body next time Jnr
roberts is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2011, 04:15 PM   #18
sd1800
Peace
I don't know about your reverse problem. But LHM can be caused by many things, first I would check the inhibitor switch on the side of the transmission. Mine was faulty and stayed in Limp home mode since the ECU wasn't getting a signal.
Formerly LV Focus XR5, AU Fairmont Ghia V8 & EBII Fairmont I6.
Now......
2012 FG MK2 XR6 Turbo
- Manual & Luxury Pack
- 302rwkw
2019 Escape St-Line
sd1800 is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2011, 01:42 PM   #19
LittleRoberts
hey all,
we got it back and the computer diagnostics said;
-servo/solenoid A gearbox elec
-VCT solenoid mechanical
-PRN321 selector error
and to clarify about the reverse turning the car around to travel up hills in reverse as 3rd gear cannot cope with the load whereas reverse is a 1st gear ratio..
so back to the diagnosis... i
ve went and chopped off the inhibitor switch from the wreck to solder it in place of the other inhibitor switch as this plug seams RATHER LOOSE!!!.. see what happens from there...
CAN ANYBODY TELL ME HOW TO 'SET' the PRN321 selector?
cheers for ever-ones help..
[i think he learning]
Old 19-08-2012, 01:40 PM   #20
holeworx
I have a AU2.been parked up for 12mths.I have popped a battery in It now and then to give it a run.it has always started.popped a battery in it yeasterday ,started it ,today I have sold it there is no way it will start.tried the battery dissconnected & ignition on ,push the brake etc.imobiliser hand is on.any hints to make it go
holeworx is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2012, 03:34 PM   #21
holeworx
engine cranks over & has spark
Old 19-08-2012, 05:25 PM   #22
BHDOGS
Fuel issues I'd say
Old 19-08-2012, 06:14 PM   #23
holeworx
tipped a bit off fuel down intake.no fire.have been tring all day.smart sheild hand is on & FAIr on dash.have done the ignition on for a hour.just going to try again with window down & a paper on door lock to see if it has cycled
Old 19-08-2012, 06:48 PM   #24
Teknoslasher
Travis - 1999 Ford AU S1
Teknoslasher's Avatar
I'm suffering the same problems with my EL. Went out today and grabbed a second hand fuel pump and distributor and tomorrow I'll grab a new coil to see how they go as I install each one. Good luck with your problem.
Teknoslasher is offline   Reply With Quote Multi-Quote with this Post
