09-02-2007, 07:25 PM | #1 | ||
hi all had the au problem drivers rear door would not lock
pulled the central locking the plastic was warped no worries ill get one from wrekers non available so off to ford them had new ones on the shelf they are redeisgned ones they told me 160 including the new wiring plug (there the standard ba ones was told) install fine tested ok so put everything back now today same old problem not locking its making and moving the atchultor i can see has anybody else has this problem i thought it could be a bad earth so not getting the full 12 volts any ideas |
09-02-2007, 09:55 PM | #2 | ||
Smile
Sounds like a bad connector in the circuit.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
09-02-2007, 10:45 PM | #3 | ||
www.TUFFCARPARTS.com
I just did a ring around today looking for one for the LHF.
Wreckers are about $70 for a second hand, Ford were $160 for the upgraded BA actuator with adapter loom. I found a wrecker in Moorabbin who's selling the same part for $125 new. I forgot which one it was though, so I'll find their number tomorrow and will post it up for you.
http://i1233.photobucket.com/albums/...psc203b7b1.jpg |
10-02-2007, 03:39 AM | #4 | |||
Fantastic Plastic
10-02-2007, 08:17 AM | #5 | ||
just last night my rear drivers side door started doing this,
10-02-2007, 10:20 AM | #6 | ||
the wrecker i spoke to
said go new reakon it would happen again he didnt have one but was honest and said it would do him out of a sale but go new because in a couple of months you will be back wanting your money back just for the info my ford keep them in stock as they sell about 1 a week |
10-02-2007, 10:22 AM | #7 | ||
you could save 20 bucks and butcher the old loom
10-02-2007, 02:07 PM | #8 | ||
i havent pulled mine apart yet as it happened last night but what is causing the proble/ what do i need to replace cheers.
10-02-2007, 03:51 PM | #9 | ||
mine i think is a lack or power/current
if i listen to the back pass door then the back drivers door the door which has failed sounds like a long click not a sharp click as the other doors going to check the voltage later then it could be that i bought a new dud so option 2 is to plug the faulty one into other door for test perposes ill let you know |
10-02-2007, 05:37 PM | #10 | |||
Fantastic Plastic
EDIT: If you bought a brand new actuator then this obviously isn't your problem ( well it shouldn't be for a brand new part anyway ! ) , but if you bought a secondhand 1 this might be the problem. cheers
10-02-2007, 05:44 PM | #11 | ||
thanks i think its power
unit not even 7 days old ill get the multimeter out tommorow i had a sunroof leak onto the drivers floor about an inch high so thats my first point of call just looked at the wiring diagram and they all join together |
17-02-2007, 01:43 PM | #12 | ||
just an update
tested the door lock with an other door its ok its the wiring or bem i thinks its 2 lots four wires join as all the door lock motors are joined now just to fine the 2 join points before they head of into the 2 pins on the bem |
17-02-2007, 02:56 PM | #13 | ||
final update
F#$%IT gave up disconnected the outside handle FIXED |
21-02-2007, 08:36 PM | #14 | ||
well tried again
ITS FIXED was the green clip that goes onto the interior door handle where it seats was worn so after a couple of movememts it moved back away from handle which in turn made the cable slack and that inturn made the door lock motor foul on the slide the opens the door from inside bought a new internal handle it made the cable 2mm longer then the slide would go past fixed something so simple worth checking if anybody else has the problem |
21-02-2007, 08:59 PM | #15 | ||
I replaced an actuator with a second hand one when I bought the car and it hasn't failed me yet. Luck of the draw.
