ThUmPeR
well as most of you know the ED flacon Gli's came out the a factory 8" sub in the parcel shelf.
when i baught my car the sub in mine was rat ***** and we took it out.... now i've got some spare time and spare cash on the side and was wondering what i should do.... the 2 option i have are..... 1. buy an aftermarket 8" to run off its own amp..??? OR 2. buy an 8" port to let in some bass from the boot install...??? im heading more towards the 8" just to get that extra bit of bass in the cabin but still not 100% sure.. whats your thoughts? cheers troy
1994 ED Falcon ICE: 7" DVD BIG MTX sterio OTHER: 2.5" exuast, Pacemaker extractors K&N Flat pannel 20" Gianna wheels Dropped on Pedders BA Bonnet bulge clear indicators all round Full EL Ghia interior |
Buy two 12inch or One 15in and put it in a box!!
I would have thought a sub in the parcel shelf would rattle way too much!
BA XR6 TURBO - SILVER & 1970 Mustang Coupe
ThUmPeR
i've got 4 12" subs in the boot............
and no it doesnt because its a factory hole and they get srewed in tight... cheers troy
EBII XR6
Just put in an 8" port, I'm not sure how mell they work in the parcel shelf, I'd like to know if there worth doing, I put the rear seat down all the time to let the bass through, its amazing how much of a difference it makes.
DEVLXR
My car has the stock 8" sub in the parcel shelf with the stock alpine sound system and altough i rekon it sounds awesome for a standard system the 8" sub in the parcel shelf rattles its *** off under big amounts of bass! and its screwd in tight as can be!
you could try taking it out and putting some padding in around where it makes ocntact to anything to take away the vibrations.
ThUmPeR
well i think i will get a 8" sub from jaycar this week and as "holmsy" said i would be putting padding under it to stop the rattles...
cheers troy
get the alpine type r 8" sub. its like $130 or something. good for mid bass
ThUmPeR
oh ok thanks for that im goin "sub hunting" tomoro for it.
has anyone put an aftermarket 8" sub in there parcel shelf at all??? cheers troy
What's green is gold
arent 4 subs enough troy? you sub whore you.
Heres me trying to work out how to fit my 15" pro comp, amp in the boot of the XD with a gas tank and access to spare....
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU - 1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps- |
#11 | ||||
![]() Join Date: Dec 2004
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
#12 | ||
Get some dynamat for the parcle shelf. I picked it up for $30 a sheet at an install place, and 1 sheet should do the shelf without any dramas.
#13 | |||
[EBGLT]
Are you sure it was not just fairmont ghia's? I know they all have the cut out for a 8' sub!
[EBGLT] Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/ |
#14 | ||
arent the 4 12inch subs in your boot producing enough bass? if its not then there is something seriously wrong with your setup. why on earth would you bother with a crappy 8 inch in the parcel shelf...im confused...
and yeah unless your car had premium sound optioned or was a ghia/fairlane/ltd then they dont get an 8 inch sub from factory. someone may have put one in at some stage. |
#15 | |||
White Car Driver
#16 | |||
[EBGLT]
#17 | ||
normality is boring
![]() Join Date: Jun 2006
i had an 8 inch jaycar sub in my eb and combined with a decent pair of 6x9's you should have plenty of bass. my sub was in a custom console/ sub box on the back seat and when a song with some good bass was played i could get the rear number plate to buzz like a much larger sub setup would
#18 | ||
ThUmPeR
well it was a factory ford sub had the ford stamp on the bottom of it.. so maybe the previous owners put it in themselves..........
and yeah the 4 subs are putting out plenty of bass but you cant have enough bass.... and plus i dont like the look of my parcel shelf... and i just wanted to add a few extra DB for the comps.. cheers troy
#19 | ||
HANK
when the seat is down this setup pumps plenty of bass into the cabin. the difference with the seat down is phenomenal!
1992 EBII Fairmont Lowered 30mm on kings springs and monroe struts/shocks Performance catback exhaust with stainless 3 in tip! Shift kit! Tinted windows n tail lights. Pioneer 200w flip face head unit 600w pioneer sub backed by my nu 640W kenwood 4 way amp Eclipse 6x9s and 6's Clear front and side indicators 115 rwkw on regular, not bad for pod, catbak! Back on the rd! nothing can stop us, not a defect or even a stoby pole!! BAHAHA ![]() |
#20 | ||
HANK
When the seat is down this setup pumps plenty of bass into the cabin. the difference with the seat down is phenomenal!
#21 | ||
ThUmPeR
well i cant drop the backseat down because the back of the dual sub box is there and is completely blocked off..
cheers troy
#22 | ||
EBII XR6
seriously dont bother with an 8", it wont even be heard over 4 12"s. Waste of money and effort. Just put a port in their if you want.
DEVLXR
#23 | ||
Dose'in around town...
well i think a 8" will be a waste of time and an 8" port hole????????? dont think that will do alot eather.... if you want to make your pastle shelf look heaps better why dont u think about customizing it????? like fibre glass......
!^_^ Yay Shed clean out!!! ^_^! Great stuff, going at negotiable prices. Click 4 Link. W.T.B.- EF/L fairmont front bar "complete"
& belt driven yabby pump, preferably red |
