hey guys the water pump pulley on me other halfs car is sloppy as hell. Can you change just the pulley or do i need to get a new water pump. Thanks
It's a ef 4.0ltr |
Tuned @ Pitlane Frankston
Umm, someone said you can change the pulley, but you require a press.
Take it to your mechanic and ask him. If the pulley is sloppy, it might be the shaft inside as well, so the pump could be fudged.
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
![]() Join Date: Oct 2006
It used to be possible to change the bearing but standard practice now is to replace the pump (which would have to be removed to replace the beraing anyway). It is usually the bearing that is worn.
regards Blue |
ok cheers guys i think i might just replace the whole thing if i need to take it off anyway
