Gunna girlie-man
hey guys, im just trying to find out, but little luck so far, what is changed on an eb falcon to make an xr6?
i know so far, head, suspension, diff ratio, cam, interior. whats the rest? cheers scott
WADE CAMS-- UNLEASH THE POWER!! <INSERT WITTY SIGNATURE HERE> Daily- 05' BA futura... work done. Cruiser- 85' VK berlina... more work done ![]() ![]() |
likes falcon's
ecu, intirior= front seats only rear were the same, steering wheel, fuel pressure regulator, boot garnish, suspension; lowered springs, longer top diff arms
the Options tag has "X" under "engine", and the red tickford cast rocker cover exhaust was a twin setup, eb falcon s rims but polished finish, red mouldings, abs, black intirior clock, ribbed metal brake booster
www.carhubsales.com.au |
Gunna girlie-man
thanks niko
likes falcon's
nurries, updated 1st post -forgot rocker cover
tickford had the twin light set up.
in some cases there are the other ones from ford that didn't i know that there where two kinds of xr8's one was the the xr8 sprint from ford that didn,t have the twin lights and then there was the improved xr8 tickford which did, now im not sertain if the 6's where the same. |
#6 | |||
@jas_23_
thanks for clarifying wasn't to sure on which model.
LSD standard, T5Z gearbox with different ratios (manual) strengthened auto, bigger sway bars, 3.45 diff ratio in auto and manual, momo leather wheel.
bigger injectors, fuel reg, exhaust, head (1mm bigger exhaust and inlet?) different spark plugs. different paint (metallic) and yerh cant really remember anything else
93' EB II XR6 factory manual Everglade Green 3" Mandrel Exhaust, High Flow everything, GT61 garrett @ 6PSI :voldar02: |
Gunna girlie-man
great, thanks for the reply's guys.
oh one more question, i know a muffler shop that can supply xr6/GT/standard exhausts for the e-series, will the xr6 exhaust setup bolt straight up to my eb2?
Injectors were standard Falcon items, and so was the transmissions. Whatever paint was available on an Spac, it was also available on the XR6.
#12 | |||
they started the bigger exhaust valves on EF XR heads. (2mm bigger) gearboxs were exactly the same as every other manual/auto falcon 6 in the line up and injectors were the same as well. |
the t on the motor (mines up for grabs soon), break booster, sway bars (front anywayz) interior, badges ofcourse ;)
#14 | ||
likes falcon's
yep, forgot sway bars!
#15 | ||
sorry too many bourbans night before chrissy ;)
ok.. http://www.fpv.com.au/theheritage/fa...alconsxr6.aspx Engine 4.0-litre, SOHC, in-line six, recalibrated multi-point fuel injection, modified cylinder head, 9.1:1 compression ratio, 161kW@4600rpm, 365.5Nm@3650rpm.(DIN) Transmission T50D 5-speed manual, all synchro. Ratios: 1st 3.25:1- 2nd 1.99:1 - 3rd 1.29:1 - 4th 1.00:1 - 5th 0.72:1 Reverse 3.39:1 BTR 95LE 4-speed automatic, XR6 calibrations, T-Bar shift. Ratios 1st 2.39:1 - 2nd 1.45:1 - 3rd 1.00:1 - 4th 0.69:1 Reverse 2.09:1 Rear axle: 3.45:1, limited slip differential Suspension Front: Independent, upper and lower wishbones, stiffer coil spring/gas strut-type dampers and anti-roll bar. Standard ride height reduced by 35 mm. Rear: Live axle, upper and lower longitudinal arms, transverse Watts linkage, stiffer coil springs, gas dampers and anti-roll bar. Standard ride height reduced by 32 mm. .... and EB S 1991 EB Falcon S Specifications Engine 3.9-litre, SOHC, in-line six, multi-point fuel injection, 8.8:1 compression ratio, 139kW@4250rpm, 388Nm@3000rpm.(DIN) Transmission T5 5-speed manual, all synchro. Ratios: 1st 3.50:1- 2nd 2.14:1 - 3rd 1.39:1 - 4th 1.00:1 - 5th 0.78:1 Reverse 3.39:1 BTR 95LE 4-speed automatic, T-Bar shift. Ratios 1st 2.39:1 - 2nd 1.45:1 - 3rd 1.00:1 - 4th 0.69:1 Reverse 2.09:1 Rear axle: 2.92:1 (manual) 3.23:1 (auto). Suspension Front: Independent, upper and lower wishbones, stiffer coil spring/upgraded gas strut-type dampers and upgraded anti-roll bar. Ride height lowered by 15 mm. Rear: Live axle, upper and lower longitudinal arms, transverse Watts linkage, stiffer coil springs, upgraded gas dampers and anti-roll bar. Ride height lowered by 15 mm. All this was from the FPV website, so standard falcons had T5OD manuals? and The xr6 autos were unmodified? The Injectors were standard gli items? and the ports were no bigger than standard yet the compression was higher? Can someone show some proof Cheers
#16 | ||
Gunna girlie-man
the info for the s pack is for 3.9L ea, eb1. the eb2 had 4.0 and more power
#17 | ||
All EBII-ED 6cyl manual gearboxes were the same. EA-EBI had different ratios as can be seen above. XR6 ecu was different, which also included transmission calibrations, which changed the shift points. Mechanically the autos were the same.
As for heads, they got slightly stiffer valve springs, different cam, and the head slightly skimmed to increase compression ratio (which reduced combustion chamber volume) Valves were the same across the range (3.9 and 4L) Intake was 47mm and exhaust 39mm. If you want proof in regards to the injectors, just compare the part numbers to a standard Falcon.
#18 | ||
Holdens Fall Apart!
Who cares there a sick car! :P
AU2 XR8, Venom Red, 200kw, K&N Panel Filter, 2.5" Lukey Exhaust
#19 | ||
i did a bit of research when buying bigger swaybars, and i spoke to someone at whiteline and they said all eb and ed, pov packs to fairmonts and xr's have the same size swaybar front and rear. 27mm front, and 22 rear. i measured mine when i took them off, and they were the same as Rollins from his XR6
Powered by Rollin Motorsport Turbo Barra ED 4L
#20 | ||
As for rollbars, im pretty sure XRs only got polyurethane bushes, which is equivalent to a rollbar of 2mm larger.
#21 | ||
The top arms on the diff aren't longer, they have a 'scallop' (for want of a better word) in the underneath of them, which combined with bolt holes that were about 20mm lower on the diff mounts allowed the top arms to sit closer to the diff than the normal ones. I don't exactly know what the benifit of this is, apparently it was to lower the rear roll center.
According to a scan of a wheels magazine I have, Tickford achieved "healthy power and torque gains with revised porting (of the head) for improved gas flow, boosting the compression ratio to 9:1" along with different cam timing, springs, spark plugs and fuel pressure. The ECU is recalibrated to match the changes and auto models get slightly crisper shifts. They got 0-100 in 7.81 and 0-400m in 15.64@145.9km/h (I think was testing with two people on board, they used to do it, not sure if they still do) top speed of 223.8km/h. Front springs are 54% stiffer than GLi (but only 12% stiffer than 'S') rears 15% stiffer, front swaybar is 16% stiffer but no change to rear bar. |
