12-11-2006, 05:51 PM | #1 | ||
Hmmmmm
hey guys,
ive got a k+n pod and heatshield sitting here off my old EA which i want to put onto the EB, but because its on gas im not sire if it will run properly with this on, cos the guy i got it off had removed the snorkel from the airbox because it was gettin "too much" air when it was running on gas causeing it to miss a bit. anyone know how itll end up? because i would really like to avoid damagin the engine. thanks Juz |
12-11-2006, 05:54 PM | #2 | ||
Gunna girlie-man
it will be fine, thats what the mixer does anyway, i have an i6 on lpg and an unshielded pod, all is good! the mixer will determine the amount of air that get in.
cheers scott
WADE CAMS-- UNLEASH THE POWER!! <INSERT WITTY SIGNATURE HERE> Daily- 05' BA futura... work done. Cruiser- 85' VK berlina... more work done |
12-11-2006, 06:06 PM | #3 | ||
gas backfire + pod filter = hobo dose :P
12-11-2006, 06:08 PM | #4 | |||
Last warning
mine never sounded anything like a dose, just a flash and a big bang. i can prove it if u want :P
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
12-11-2006, 07:02 PM | #5 | ||
Rymers probably wouldn't want you to prove it :P again
A backfire would never sound like a dose anyway, but I have a vivid imagination and am very bored this arvo. |
12-11-2006, 08:04 PM | #6 | ||
Hmmmmm
if it does backfire would it do any damage?
12-11-2006, 09:35 PM | #7 | ||
Gunna girlie-man
gas cars backfire often, it would be no different if you had the standard airbox, although a backfire with the air box, blew mine to pieces, so the pod is a great idea!!!! the pod will let the smoke out quick
13-11-2006, 02:49 AM | #8 | ||
ELMONTY
the gas systems usually have a pipe that faces into the snorkel against air flow, so if the air pressure is too great the gas system compensates to keep the right pressure. i dunno what would happen if you used a pod without an airbox? because this system would have no use without the box.
97 EL Fairmont - Regency Red |
13-11-2006, 10:42 AM | #9 | ||
I had a pod on my car which is also LPG, but it started idling rough, so i took it off. Im pretty sure that K&N doesnt recommend using them with gas powered cars. It may still backfire depending on ur gas setup, but instead of the airbox flying off, id say it would be the pod filter lol.
13-11-2006, 05:31 PM | #10 | ||
Yup it'll blow the pod off if it backfires, used to happen all the time in my mates gas powered VN.
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
13-11-2006, 08:34 PM | #11 | ||
stktlr
i have the same setup,v8 on strait gas it runs perfect and never backfires
eb v8, dedicated gas,twin pipes,ghia interia,au console,el mirrors,drilled and slotted rotors,lowered with superlows and koni 3 ways ...:evil_laug and maybe selling : |
13-11-2006, 10:12 PM | #12 | |||
bettering 13.7
std stroke, alloy heads, comp cam, tfs manifold, 75mm t/b, 70mm maf, 30lb inj, adj fuel press reg, twEECer FPV/Tickford Club of W.A Performance is Electronic BPT Motorsport |
