05-11-2006, 10:44 AM | #1 | ||
What Wheelspin?
as some may be aware, i was having MAJOR problems with my car. would drop cylynders, cut out fuel pump while driving, wouldnt change gears, and then suddenly go into limp mode. well the problem was a VERy simple fix.
my chiptorque chip had shi t itself. so one it was removed, car hasnt skipped a beat. also, becuase i havent had it a year yet, its covered by warantee. and when i get my new chip back, its goin to be tuned to my new crow cam i have sitting here. the ru-tune wont cost me a cent. so if anyone is having and running issues with thier car, especially limmp mode, and they have a chiptorque chip, i suggest they take it out and then see how they go. apparently chiptorque have made a faulty batch of around 100 units. was due to the proccessor. cheers, John
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw) 2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned) |
05-11-2006, 01:54 PM | #2 | ||
- BOOYEH -
Sweeeeeeeet John. It all worked out for the best. Minus all the trouble and heartache you have endured trying to find the problem :P
1993 EBII Fairmont Turbo T04e 7 psi
05-11-2006, 04:35 PM | #3 | |||
Ea Falcon S
very nice.....BTW how much was the chiptorque chip and was that with a tune prigrammed in??.....
Jarv Smith 88' Ea Falcon S 3.9MPFI 5 speed Manual Motivator Headers with 2.1/2" RedBack system XR x GT Hybrid Body 15" 'Snowflakes' 90' GL Interior Custom Black Vinyl Roof Custom Console Lid 9" LCD + PS2 Boss CD/MP3 head unit 50x4w Quote:
06-11-2006, 01:04 PM | #4 | ||
What Wheelspin?
chip cost me 540 bucks with a custom tune brand new
13-11-2006, 08:34 AM | #5 | ||
Extremely Covered
I think I may have the same problem. It's intermittent, but happens every now and then. When I start it, revs low, like it's running on 2 cylinders, temp light on with guage at zero, sometimes it'll go into limp mode, no power, and basically runs like a dog.
However, if I pull over, turn the car off and restart, it's fine. Runs like a beauty. It's a 96 Fairmont with the chiptorque. Did a diagnostic check on it and came back with a " 511 - Internal EEC Fault". I'm guessing that If I pull the Chiptorque out it should run sweet? |
13-11-2006, 08:53 AM | #6 | ||
What Wheelspin?
yer give it a go. its as simple as pulling the chip.
14-11-2006, 12:16 AM | #7 | ||
Extremely Covered
Yep, was the chip. Ended up getting it to run like crap. Pulled the chip and all was fine again. Except now I have to stop the idle from surging.
14-11-2006, 08:56 AM | #8 | ||
What Wheelspin?
did u buy ya chip over 12 months ago??
also, what cam u running??
14-11-2006, 08:24 PM | #9 | ||
Extremely Covered
Well had a bit of luck today. Rung Chiptorque regarding the intermittent probs with the chip. I didn't actually buy the chip however we traced it back to being JULY last year. Anyway the chick said that because it was intermittent it doesn't actually sound like a prob with the chip, rather a connection somewhere.
So, after closer inspection of the chip, I noticed that a couple of the tongues on the connector, were bent below the plastic stops. It seemed also that a lot of the probs were also happening when it was hot. Maybe resulting in the pins not connecting. Anyway fixed a $600 chip with a 0.5c pin by bending the tongues so that there would be pressure applied to the board. Guess what,- problem solved. Haven't had any intermittency probs so far. As for the cam, according to the chip it would be XR6 equivalent, however according to Chiptorque, it's a fairly aggressive cam. PM4 or xx4 something or other. So I'm quite happy that I don't have to fork out for another cam or tickford computer now! |
15-11-2006, 10:05 PM | #10 | ||
Extremely Covered
Well looks like spoke too soon. Happened again on the way to work. However I've noticed that it doesn't happen when it's cold. So the drive to work was my test (about a 40min drive).
About 20mins in it starts coughin and splutterin so I took the Chiptorque chip out. Car runs fine again. Did this a couple times to make sure that I had isolated the problem. Noticed that the ECU gets pretty darn hot. Got the digital temp and strapped it to the case of the ECU. 3 times at 37degs the car started to run like crap. Prognosis is that the chip shuts down (limits it operation) I suppose at roughly 37degrees. All I have to do now is to run some sort of piping somehow to the ECU to keep it cool. |
16-11-2006, 10:26 AM | #11 | ||
What Wheelspin?
well i sent my chip back and they confirmed it was a faulty CPU in the chip and fixed it under warantee
