06-03-2005, 11:28 PM | #1 | ||
Low and Loud
As some of you know, I recently fitted a new motor to my car.
Reco 3.9 Block Reco EF 4.0 Head Currently running a EA cam, but will be upgraded within 2 weeks. I was using the EA airbox, EA Airbox piping, ED Snorkle. I recently replaced the ED snorkle with a XH one as my ED one got a little crushed (Thats another story), but thought an XH one would make the car a little quicker or at least the same. But its slower? The car doesnt take off as well anymore, I have to push on the acelerator more now, and now feels more like im driving with my old motor??? Is this even possible????
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon : |
06-03-2005, 11:36 PM | #2 | ||
Custom user title
u are just getting used to it................ id bet u its still just as quick
06-03-2005, 11:45 PM | #3 | ||
Low and Loud
The wierd thing is, i put the ED one back on and it was like it was.
The main difference is that it doesnt seem to kick down as quick with it? If thats even possible????
06-03-2005, 11:55 PM | #4 | ||
Smash the Boost
Maybe your engine has decided to go against the basic laws of internal combustion engines and decided that it'd like less air to go with the factory rich fuel mixture...only explanation I know of!
the difference between snorkels IMO is bugger all anyway, but the effect still shouldnt be detremental!
2023 Hyundai Palisade 1971 Fairmont Sedan 1974 SWB F100 Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
06-03-2005, 11:57 PM | #5 | ||
Low and Loud
LOL maybe my injectors are scragged and not running ritch enough?
06-03-2005, 11:59 PM | #6 | |||
Smash the Boost
07-03-2005, 12:00 AM | #7 | ||
Low and Loud
ohh there is one thing thou, the airbox has been modded and has a PVC pipe out the side that been taped up. Would this be affecting it?
07-03-2005, 12:59 AM | #8 | ||
Two > One
get somone to either install the XH or the ED snorkel, go for a drive, $10 u cant pick which one it is.
07-03-2005, 06:06 AM | #9 | ||
ooga-lagga-ligga-lagga
u should reset the ecu, i think it could[?] solve the problem. i put one on my EB, reset ecu, took it for a spin and could easily feel the difference. mine is modded though, cut the two pipes things and basically made it into one big chamber. mine could be a different situation though.
i would take up your offer Walkinshaw but ur a bit far away, and plus i dont think mine meets original xh originality anymore..... also just thought that maybe the cam could be the problem (more so if cfi as they might be different to EA MPefi- dunno correct me if wrong please). but being originally designed for a lower compression, extremely low flowing head in comparison to the ef style and totally different fuel and ignition requirements. The cam might need the snorkel for that tiny bit more airspeed/possible volumetric issue or something. very similar in how a smaller airfilter (say 14" x 1.5" type) is said to give more power on a 4v cleveland than a 14" x 3" type. |
07-03-2005, 08:59 AM | #10 | ||
Last warning
how good are the injectors?
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
07-03-2005, 11:17 AM | #11 | ||
Low and Loud
Needturbo6 - Ill try resetting my ECU
John - I have Noo idea how good they are, they aint noisy like the other set i had and they are chads old ones that were in his trailer? lol
07-03-2005, 08:07 PM | #12 | ||
E-Series Owners Club
Mick, if you wanted to try them, I have my old EA injectors sitting here.
Try resetting the ECU first, if that doesn't help then you're welcome to give them a go ;) |
07-03-2005, 08:54 PM | #13 | ||
XH snorkle is the biggest placebo mod ever.
07-03-2005, 09:22 PM | #14 | ||
windsor user
the only difference guys is that it looks better...
geebus |
07-03-2005, 09:28 PM | #15 | |||
I think you meant ****mod..? : : :countdown :countdown :countdown 3 of them :gren: |
07-03-2005, 09:33 PM | #16 | ||
Naw, Placebo as in you think it does something, it sounds like it does something, but in reality you just spent 30 bucks on a bit of plastic when you could of spent 30 bucks on a slab.
07-03-2005, 09:45 PM | #17 | ||
Two > One
Rob is 110% correct. Hence my $10 bet
07-03-2005, 10:03 PM | #18 | ||
But Wayne is right, it does look better.
07-03-2005, 11:18 PM | #19 | ||
Low and Loud
Well i found out whats causing my car to lag like crazy. My diff has gotten alot worse.
you know the normal Single Spinner action? Well mine now makes a really loud Wining sound when driving, and while having the back of the car off the ground this avo, I noticed that when one wheel is spun the other doesnt move and there is a large amount of grinding kinda sounds comming from the middle. ANYONE GOT A EA DIFF????!!!!!!! Ill take EB if its in working order
07-03-2005, 11:24 PM | #20 | ||
placebo is a medical term.
i don't know why i just found that odd.. haha. :| Placebo : a medication prescribed more for the mental relief of the patient than for its actual effect on a disorder. that's just ONE example. lol. it's all about the cars!!! |
07-03-2005, 11:30 PM | #21 | ||
i think my point was, uhm... that i've never heard placebo used as an automotive term.
oh and Mick, If ya wheels ain't fly.. ya gotta hit us up. for a pimped out ride! You need to talk to X about your problems. lol [/end stuipinessfortonight] |
07-03-2005, 11:30 PM | #22 | ||
You idiot, Placebo is a band.
07-03-2005, 11:35 PM | #23 | ||
i have heard of the band placebo, do they make the XH snorkels..?
Placebo suck! |
07-03-2005, 11:48 PM | #24 | |||
Low and Loud
LOL i allways wondered what a coffee machine in my centre console would be like :P "You got to pimp my ride, daaaaamn right"
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon : Last edited by InitialD; 07-03-2005 at 11:49 PM. |
08-03-2005, 12:08 AM | #25 | |||
08-03-2005, 12:24 AM | #26 | ||
Two > One
yes wierd as in crap
08-03-2005, 05:23 AM | #27 | ||
if you guys are saying that a stock xh snorkel doesnt make a difference then id have to agree as there isnt much difference in volume.
but try opening up the middle and it just about doubles the volume, there is no doubt in my mind the xh snorkel (and the time taken to modify it) was worth it. |
08-03-2005, 09:08 AM | #28 | ||
Last warning
the XH snorkle will make a difference.. if thats whats causing a restriction.
simple as that :P
08-03-2005, 09:18 AM | #29 | ||
The XH snorkel DOES flow more, but most likely a stock(ish) car doesn't create any kind of restriction at the snorkel anyway. So it's probably kinda pointless. But hey, for 30bucks, what do you expect??? :P lol
08-03-2005, 10:50 AM | #30 | |||
'Save money? pfft'
