Old 12-04-2006, 07:51 AM   #1
The Monty
Just slidin'
The Monty's Avatar
Default No heat from heater.
Ive tried every setting possible on my climate control, and I just cant get any heat to come out. Air conb works OK, but when I turn up the heat at all, it just stays cold. Any suggestions?
MD Mondeo - For the family
NP Pajero - For the adventure
Old 12-04-2006, 09:06 AM   #2
phildee
phildee's Avatar
Happaened to mine once, I just did the reset procedure and it worked fine afterwards.
I cant remember 100% how to do it tho, I 'think' it was just hold the outer 2 buttons down for a few seconds (off and the one which you choose which vents the ait comes out of) maybe someone can correct me if im wrong on that.
Cheers, Phil
phildee is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2006, 10:00 AM   #3
JC
JC's Avatar
Let the engine warm up?
Ford Performance Club ACT
Old 12-04-2006, 11:09 AM   #4
The Monty
Just slidin'
The Monty's Avatar
Thanks Phildee, will try it in the morning, and thanks JC but I was trying to get this going from the time I left my house this morning (5:00am) until I got back (7:00am) continuous trip, so thats not it unfortunately.
Old 12-04-2006, 11:40 AM   #5
autickfordfairmont
Tickford Equiped
autickfordfairmont's Avatar
Yep your right, Vent Location & Off at the same time and that will run a self diagnostic test & reset.
If any error codes come up, note them down, and then run again. If error codes still come up post em up and some maybe able to tell you whats wrong, if second time no codes come up, it should work fine.
You can also enter diagnostic mode, and check out coolant temp, cabin temp etc etc on there by pressing and holding Vent pos, A/C and Auto.
Cant remeber the exact order but should be something like
L - Operator Set Temperature in degrees Celsius (°C)
2 - Cabin Temperature in degrees Celsius (°C)
3 - Ambient Temperature in degrees Celsius (°C)
4 - Evaporator Temperature in degrees Celsius (°C)
5 - Engine Coolant Temperature in degrees Celsius (°C)
6 - Sun load Sensor Reading
7 - Fan Speed percent (%)
8 - Temperature Blend Door Flap percentage (%) opening
9 - - Aircon and Vent Selection (00 A/C Off Floor) (11 A/C On Face) (22 A/C Off Face/Floor) (33 A/C On Screen/Floor) (4 Screen)
H - Water Heater Valve operation (1=On, 0=Off)
Genuine Tickford Equiped 1998 AU Fairmont
Mods: ....... Dash mat & Air Freshener, does that count as a mod??????
Sports Exahust, Tickford Intake Snorkle, K&N Filter, NGK Plugs, Top Gun Leads
TS50 Front Bar with Fog lights, TS50 Rear Bar. Injected LPG System,
autickfordfairmont is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2006, 11:51 AM   #6
autickfordfairmont
Tickford Equiped
If your a member of Fordmods.com jump over to the link below. It tells you what error codes are what and stuff like that.
http://www.fordmods.com/forums/documents.php?doc=9
Old 13-04-2006, 04:24 PM   #7
The Monty
Just slidin'
The Monty's Avatar
OK, I tried holding in Vent Location & Off at the same time, I got some noise coming out of my engine, it went cold, hot (Yes hot) then turned off, but didnt give me a number. But it did get really hot, which means it is working, but maybe a loose wire or something, that is stopping the ecu recieving the signal to let hot air through? I have no idea guys, Ill keep trying to sort it out.
Old 17-06-2006, 03:27 PM   #8
The Monty
Just slidin'
The Monty's Avatar
Sorry to bring this up again, but now my mums is stuffing up. Can you re-set the non climate control heater at all? Its an AU1 Forte.
Old 17-06-2006, 07:20 PM   #9
Burley
CRE.87V
mine au1 xr6 did the same....pulled out the stereo surround with the controls for air con...bought a new heater valve (about $5) put it in...and check that the wire to change temp is plugged in...to do this...open the glovebox..push the sides in to release location plastic for it....now where u can see there should be a wire with thread at the end..make sure this is connected to a whitish clip clip into temp or vacuum???? if u dont understand.... turn ur temp from hot to cold....if there is no wire moving a slider then thats ur prob....not sure bout this but the climate control may be the same thing behind glovebox.....wire air con not mechanical
hope this helps....
Burley is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2006, 06:27 AM   #10
The Monty
Just slidin'
The Monty's Avatar
Cheers mate, checked the wire thing, it all moves like it should. It was working one day not the next. My Fairmonts never worked form when I got it, re-set it and it worked fine. Where do you get one of the heater valves from? And have you got a part no.? Thanks.
Josh.
Old 23-08-2007, 10:50 PM   #11
roop69
I've had similar problems with cold air only from the CC. Tried your fix with good result. Thanks
roop69 is offline   Reply With Quote Multi-Quote with this Post
