EF94
Can anyone tell me what upgrades have been done
on EF v8 falcon GLI with OPT20 on ID Plate |
V8 Powaah
Its a cop car
should have 3.23 LSD, Fairmont Interior Lighting (usually with a dimmer switch), Sports Suspension, Police Instrument cluster (similiar to the Fairmont one but with police calibrations) and most likely will also have ABS. It gives you a few tidy options which bring a little closer to an XR. Im actually instrigued that the police optioned up a Gli with a V8. Im guessing that it may be a WA police car (by the way is it white?)
FG G6E Turbo- Seduce & Cashmere - Sold XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
BLUE OVAL INC.
They also have different ECU with a different shift pattern.
I have an EF XR8 OPT 20 We should start a EX -CHASER thread to see who else has a chaser |
Welcome Nick
I have an ex chaser. For now ![]() It's the only EL I have owned so I'm not 100% sure the differences between Gli and police pack but I know for sure there is adjustable speedo, oil cooler, ABS, LSD, dual airbags, better shift patterns and slightly better electrics. |
EF94
Yes it is white
how much diffence between the Fairmount custer & police custer panel how do you adjust it |
#6 | |||
KOEO, hold button for odo in, and wait till it says speed, can be adjusted up or down to 20% |
EF94
what is adjusted up or down 20%
BLUE OVAL INC.
I read somewhere that a chaser trans wont change into 4th until it is over 65ks so i figured that was just a different control module and mine also seems to have a firmer change than any other ford ive driven
#9 | |||
#10 | |||
cross breeder
Like xk-xf's?
http://www.ozfalcon.com.au/ |
#11 | |||
#12 | |||
Driftin shopping trolleys
VZ Calais 5.7ltr cammed, stalled, and the rest. 04 BA XR6T ute |
#13 | |||
Workshop manuals show nothing, and MINE is exactly the same as other cars I own, so in EL it DEFINATLY is no different. |
#14 | ||
well ur wrong
#15 | ||
i could definatly feel it didnt go into 4th under 65kms and was quite a bit different to the stock ecu i had
maybe u have a faulty or fake excop ecu
#16 | |||
I have every Tickford EL V8 model here, from Concorde, ELGT, FBT, ELII XR8 and XHII XR8....care to rethink your "u r wrong" statement? |
#17 | ||
And just to clarify something, the FBT will go into 4th under 65kph with the gearbox set in Max Perf mode.....
#18 | ||
maybe its because mine was a 6cyl and not an 8.. becuase there is definatly a noticable difference between the stock 6cyl ecu and the cop 6cyl ecu.. v8's must be different..
#19 | ||
6 cylinders have a different trans program. V8s don't.
#20 | ||
V8 Powaah
Still dont know about the ECU thing. I had a QLD Police Detective car (purchased from Bryan Byrt, Mt Gravatt) and it used to shift into 4th under 65km/h and in fact it felt like every other EL BTR 4 speeder.
#21 | ||
I've never cared to look but I'll watch on the way home to see when it shifts to 4th and post up tonight. 4 litre ex police car.
#22 | ||
Are you lot talking about 4th or overdrive? Because holding it in 3 on the shifter will infact hold it to 4th gear but it wont go into torque convertor lockup and hit the high overdrive.. overdrive usually kicks in at about 70ks in my EF auto and its a totally standard box and ECU.
#23 | ||
Economy: 4th 60-65 lowest I could get it
Power: 4th 80-85 ditto Cheers |
