Old 07-03-2006, 09:32 PM   #1
Jason[98.EL]
Jason[98.EL]'s Avatar
Question Resetting Ecu In El
G Day all just wondering on the procedure to reset the ecu in a 98 el
hope someone can help me on this
jason
[SIGPIC][/SIGPIC]
Old 07-03-2006, 09:34 PM   #2
niko
likes falcon's
niko's Avatar
umm pull battery terminal off for 1hour i think?
www.carhubsales.com.au
Old 07-03-2006, 10:13 PM   #3
jason257
gunna b tuff
pull the engine fuse out for at least 5 mins, put it back in, start it but do not touch the accelerater as to it is configuring air fuel mixture. leave running for 5 mins. turn off then start up again, ecu will be reset
jason257 is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2006, 10:28 PM   #4
the_scotsman
MY21.5 Mustang GT
the_scotsman's Avatar
to reset it just remove the battery for 10 minures...no more no less.....let it idle for a few minutes then drive it as normal, it will relearn everything over the next few days...
Old 08-11-2013, 11:42 PM   #5
matan
Default Re: Resetting Ecu In El
I want to get rid of the rough idle that resulted from my bf egas backfiring. I see a different method of re setting the ecu on every note I check. some say an hour some have an formula of switches and loads after start up.
is there a method that is the standard. where doI find it?
matan is offline   Reply With Quote Multi-Quote with this Post
