Site Support If something isn't working or you have a suggestion ( a nice one !! ) let us know here. |
Under "Ford Passenger Cars" we have:
Performance - FPV - 6's & 8's XR6T and Typhoon - 6's Why don't we have a special area for the die hard XR8 fans? |
dose sound like a good idea
#5 | |||
Cuban... nothing like it
Aussie Bloke
At this stage their isnt the demand for a seperate area, but if the die hards grow enough it may be an option in the future M14a-McLaren is right in his direction
#6 | |||
Foo Fighter
#7 | |||
I'm glad you asked the question, I've been wondering the same thing since I joined. Feeling a bit left out ! ![]() |
But there is plenty of talk on the XR8s in other subforums as well ... kinda gets confusing at times ... as there is the Falcons thread ... then AUFalcon as well as the multitude of other sections as well ... also the deleted link section as well. Then there's a performance section as well ... and the different XR club sections to post in as well. Even the Utes section for all of XR models as well.
There's plenty of sections to post in already on here as it is ... adding another section will just double up on more posts ... as some people like to double post in different sections. I know I have on the odd occasion (yes guilty as charged)
I noticed the XR6 N/A also has no specific section. Maybe an "XR8 and XR6" section - joining forces to get the numbers up?
1966 Ford Mustang coupe. 347 stroker, PA reverse manual C4, TCE high stall converter, B&M Pro Ratchet, Edelbrock alum heads, Edelbrock intake manifold, MSD ignition, Holley Street HP 750 CFM carb, gilmer drive, wrapped Hooker Super Comp Headers, dual 3" straight through exhaust, Bilstein shocks, custom springs, full poly suspension, American Racing rims, Open Tracker roller spring saddles and shelby drop. Still to go - Holley Sniper EFI with integrated fuel cell. |
Viper FG XR6 Turbo
i reckon a better idea is have a section for...
FPV V8's and XR8 FPV I6's and XR6 |
BOSS 5.4L Enthusiast
We have a XR6T & Typhoon Forum, why not just make a Boss powered forum instead of the FPV one?
#12 | |||
#13 | |||
#14 | |||
#15 | |||
#16 | |||
#17 | |||
Good point, will have to look at making some changes then over the next month or so
#18 | ||
Thanks mate!
#19 | ||
Historicly it was FPV (all BOSS 290s), XR6T, (all rabid zealots
![]() Pursuits, Tornados & SPs all qualify for FPV & esky. The above plus GT, GT-P & Typhoon qualify for FPV both F6 models qualify for 6T&F6 Now add the confusion of XR, XR6T & XR8 sedans & utes what do you do? Have 50 different subforums? Allow XR6N/A postings in FPV and have threads about manual window winders and banjo diffs? Someone will bite over that I and certain.... Whatever is done someone will not be happy. e.g. should a problem regarding the ICC in a new Tornado go in FPV (it is a FPV), F6 (it is one of them too), esky (ah so that is why there are no back seats) or I & E tech (where it will not be read by half of the userbase..... Good luck guys..... |
#20 | ||
[QUOTE=Now add the confusion of XR, XR6T & XR8 sedans & utes what do you do?
Have 50 different subforums?QUOTE] I can see what you are getting at, but I think you may be complicating the issue somewhat. Quite simply, all we need is an XR (BA & BF) sub forum under performance. |
#21 | |||
[QUOTE=Shockwave XR8]
#22 | ||
Too true Jabba. Lets keep up the pressure here guys! :voldar02:
#23 | ||
Yep keep pushing amd nagging the admins, a bit of abuse and sarcasm works well too.......
#24 | |||
Back on subject. Even the E series XR's get to share the same section with the rest of the Tickford models.... Just because the BA XR was assembled by ford, dosn't make it a lesser performance car... An XR is an XR whether Tickford made it or Ford... And as you know Both the 260 and 290 engines are made at FPV. |
#25 | ||
... And as you know Both the 260 and 290 engines are made at FPV.[/QUOTE]
About time someone pointed this fact out.So it becomes quite easy,just put the XR8's in the FPV forum. |
#26 | ||
I think this is the most logical solution as we already have the XR6T grouped with the FPV Sixes. So yes, I reckon BA/BF XR8 Boss 260 should be grouped with BA/BF GT/GT-P Boss 290.
#27 | ||
Sounds good to me as mechanically they are very close .
FPV + XR8 is the go ! |
#28 | |||
#29 | |||
#30 | |||
Using your logic, let's have a forum for all cars that have tyres. I see you drive a Typhoon... let's scrap your sub forum and group you under standard Falcons then too. Bit of a difference hey? |
