19-08-2005, 03:18 PM | #1 | ||
With fuel prices going through the roof is it worth installing an LPG system. I'm aware that it's a performance car, however the current fuel prices are giving me the s! $1.26 for unleaded and much more for premium, LPG is $0.46.
Would you convert? |
19-08-2005, 04:17 PM | #2 | ||
ouch, no way! :
19-08-2005, 05:07 PM | #3 | ||
LPG > You
Definitley. LPG is an excellent fuel, and being twice cheaper then petrol doesn't hurt.
LPG Lovers Association President & Member #1. : |
19-08-2005, 05:26 PM | #4 | ||
1995 EF Futura
Straight gas would be more the way to go for a v8. Dual-fuel (gas and petrol) is more for everyday family cars. An xr8 is NOT meant to be a family car. If you were to run it on gas alone, raise the compression and have it tuned for gas, she'd run really well, give you great performance and be pretty cheap to run. From what I've read, running on lpg causes less engine wear then petrol. I'm not sure how much more it'd cost to convert to straight gas, rather than dual-fuel, but it's definitely worth a look. However, if your AU is a family car and you're not after performance, dual-fuel is certainly a good option, even though she won't give you as much power.
19-08-2005, 05:37 PM | #5 | ||
Viper FG XR6 Turbo
[QUOTE=supa eb]running on lpg causes less engine wear then petrol./QUOTE]
actually its quite the oposite, that is why factory gass engines have hardened valves as gas simply doesnt have the lubricating characteristics as petrol does. if you must, streight gas is the only way, but expect a loss in power |
19-08-2005, 05:45 PM | #6 | |||
19-08-2005, 05:46 PM | #7 | ||
Replace the egg beater (RX7) with an economical buzzbox (gassed up Pintara perhaps sorry couldn't resist Steffo) and for God's sake leave the XR8 alone! Converting it to gas is about as bad as following the Poms in The Ashes...
19-08-2005, 05:48 PM | #8 | |||
[QUOTE=EF_Dave]
About the only difference between a straight gas motor and a ULP motor these days would be compression ratio, spark plugs and possibly thermostat. Having said that, if you go the traditional mixer in the intake pipe method, you WILL lose a heap of power (approx 10 to 15%), but if it's an AU3, then you will still be left with as much power as an AU1 (roughly). I would go straight gas as it's the only way to maximise the engine tune - dual fuel is always a compromise on tune as the tune needs to be different for petrol and gas. Steffo - what the hell is twice cheaper? Do you mean less than half? Where the hell did you/do you go to school, and what language do they teach there? LOL.
19-08-2005, 06:17 PM | #9 | |||||
LPG > You
[QUOTE=EF_Dave]
And why should there be a power loss? Bump the compression and adjust ignition timing.. and there should be a power increase if anything. Quote:
19-08-2005, 06:29 PM | #10 | ||
Steffo - I have, and yes I was having a laugh. I just wasn't really sure what you meant!
When you do an LPG conversion that mixes the gas in the air intake tubing, you will lose power as you are restricting the intake from 75mm down to about 50mm, therefore reducing the available fuel/air mixture. Also, you cannot advance the timing etc on an AU1/2/3 XR8 - not without a chip of some sort. So, if all you are doing is a "traditional" LPG conversion, you will lose power. But there are ways to get the power back - at additional expense, of course (or should that be half cheaper, LOL).
19-08-2005, 06:38 PM | #11 | |||
V8 Turbo Hoon
19-08-2005, 06:45 PM | #12 | |||
19-08-2005, 06:55 PM | #13 | ||
TL40 Wagon?
I reckon dual fuel would just spoil the car and spend more on conversion than you would save in quite a while.
A proper performance lpg only set up would be very nice but there are few people who can do it well and they cahrge well for the work and parts. Seriously if you can't afford the fuel for a V8 sell it and buy a cheap to run dogbox car for a couple grand or better still a bike (motorcycle that is) to run around in and use the XR as a weekend warrior. Cost you about the same really when you add it all up. |
19-08-2005, 07:05 PM | #14 | ||
Turbo Falcon Fiend
This is a conspiracy.
GAS Is great. I think the only reason people say you should not use it is because they are trying to protect the secret. I am yet to come accross a person who has gas and thinks it is bad. I am also yet to see anyone remove gas from a car, because they dont like it. Do it. You will feel like you are getting away with something everytime you fill up. |
19-08-2005, 09:00 PM | #15 | ||
19-08-2005, 09:19 PM | #16 | |||
Barra Turbo > V8
btw it takes about 20000kms or more to re coup ur money forked out 4 the conversion
-2011 XR6 Turbo Ute - Lux Pack - M6 -2022 Hyundai Tucson Highlander Diesel N Line |
21-08-2005, 06:26 PM | #17 | |||
Walking with God
GK |
21-08-2005, 08:28 PM | #18 | |||
Viper FG XR6 Turbo
Thats alot of power to lose |
21-08-2005, 09:24 PM | #19 | ||
The Guy You Love To Hate
why would the BF gas falcon have less power than the BA gas model?
22-08-2005, 08:06 AM | #20 | ||
I think it was the AU EGAS motor that was 157kW .... the BA was close to the 165-170kW mark.
There is a difference between the 2 ... I have an AUII EGAS ute .. and my fiancee's father has a BA MkII EGAS ute ... mine runs well ... but nowhere near as good as the BA ... mine you the BA is having probs with the spark plugs and smooth running comapred to mine. But hell ... the BA EGAS motor goes pretty damn good ... I was surprised ... much better than the AU EGAS motor
22-08-2005, 09:40 AM | #21 | |||
I think the AU straight gas motor is around 136kW. The BA E-gas is definitely 156kW same as BF.
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
22-08-2005, 09:41 AM | #22 | ||||
22-08-2005, 12:22 PM | #23 | ||
thanks for all the input. I sure stirred things up !
22-08-2005, 06:51 PM | #24 | |||
22-08-2005, 06:53 PM | #25 | |||
Low down though ... the BA EGAS has punch though (mind you it is a tray back XL model)
22-08-2005, 07:14 PM | #26 | |||
4.0L Intech Dedicated LPG 6 cyl Bore and stroke: 92 x 99 mm Power: 143kW at 4500rpm Torque: 362Nm at 2750rpm Overhead camshaft, 2 valves per cylinder Fuel system: EEC V fuel injection Compression ratio: 9.6:1 |
