16-01-2005, 11:21 PM | #1 | ||
hi all, i just registed with the forums
my old faithfull lsd pack it in,i've purchased a 2.77 lsd out of an ea, just until i have the money to rebuild mine with 3.7's. how ya's think my eb2, with a 5 speed, is going to go. not to slow i hope! :eclipsee_ . |
16-01-2005, 11:51 PM | #2 | ||
hibernating
guessing take off will feel a bit slower.. and it wont be reving as high when cruising so you might get better fuel economy
17-01-2005, 12:34 AM | #3 | ||
likes falcon's
should still rip up, my bro's 4speed xf does and quite well to lol (on private property)
www.carhubsales.com.au |
17-01-2005, 12:37 AM | #4 | ||
FPV GT-P 335!
you'll need to change tailshaft if yours has the bigger Pinion.
Current rides - 2013 FPV GT-E MK2 & 2010 FPV F6-E Tuned by Michael J's & Son. |
17-01-2005, 12:46 AM | #5 | |||
17-01-2005, 12:56 AM | #6 | ||
Two > One
its the yoke flange thats the prob. EB2 tailshaft runs a flange style connection to the pinion, where as EA run a uni style conection.
17-01-2005, 01:03 AM | #7 | |||
17-01-2005, 10:20 AM | #8 | ||
The trailing arm mounts on the diff will be narrower as well.
17-01-2005, 12:10 PM | #9 | |||
Two > One
17-01-2005, 11:04 PM | #10 | |||
soon see tomorrow |
23-01-2005, 07:42 PM | #11 | ||
Well ,i got the diff in last tuesday. still goes hard, did't have to many dramas. just took it to the local mechanic to swap the pinions,i didn't have a soccet big enough.
The revs sit around 16/1700rpm at 100k, still got to change the speedo cog in the trans ,but unsure what colour cog it is, i know there's only 3/4 colours, maybe someone can help. thanx for the advice. Last edited by EF302; 23-01-2005 at 10:36 PM. |
24-01-2005, 03:43 PM | #12 | ||
I used the original 4spd tailshaft that was in my old EA behind a 4spd, 5spd and a 3spd with out any worry, the seal ran on the same part of the yoke behind all 3 boxes. They are all the same, except the EBII where they went to the different pinion setup.
2003 Narooma Blue BA XR6 5spd Manual. Pacemaker 4490 Extractors 2.5" Exhaust High Flow Cat SS Inductions "Growler" CAI Underdrive Pulley Mal Wood H/D Clutch Custom Tune 18" XHP Sabre's 12" Kicker Sub 169.2 rwkw
24-01-2005, 11:58 PM | #13 | |||
My 5 speed EA pulled 202kph on the dyno in 4th gear with a 2.77 diff!!! So you will have good top end hehe. |
25-01-2005, 12:08 AM | #14 | |||
did the 2.77 come in both manual & auto, or was it just auto's. Is there a reason why? |
25-01-2005, 12:16 AM | #15 | ||
Two > One
2.77 was EA series 1 auto. It was used as the 3 speed didnt have overdirve, and was used as a vein attempted to control highway rpm.
25-01-2005, 12:21 AM | #16 | |||
27-01-2005, 09:37 PM | #17 | ||
Custom user title
um ... even with 3.27's in 4th in a t5 u can do 215 kmph, at 5750, with a set of 2.77s at 5750 in 4th (1-1) you would do 253 kph on rev limiter...... thats running a 205 65 15 inch tyre or a tyre with a 25.5 inch diameter... 100 kmph is 1660rpm in 5th
