Hi all,
looking for some advise on how to remove the stains from the under bonnet insulation panel. any advise on products and methods that you have used with success is appreciated ![]()
AU XR8 series II N/A 6 speed manual 426HP 730Nm 1/4 mile: 12.44 sec @ 110.42 MPH Build thread http://www.fordforums.com.au/showthread.php?t=11410574 |
DartAUxr8,
I wouldn’t touch it, the material is so delicate, it will fall apart. Even if you hosed it, it could possibly damage the material. I just took mine off, even removing the tabs has damaged the material. I would look for a good second hand one or after market. Cheers |
#neuteredlyfe
![]() ![]() Join Date: Apr 2012
I have actually painted one of mine in satin back from a rattle can.
I wiped it down with a damp rag (very gently mind you) firstly then hit with several light coats of paint. Make sure with each coat you come from a different direction. I did it about 6 months ago and it still looks great. Can post some pics tomorrow if need be. |
#5 | |||
I think good second hand ones without staining would be a rare find. there is a company in Vic that sells them but nor for XR models. Cheers Shane
I agree black vinyl dye it will stay black for a while
Wouldn’t attempt to clean either just keep painting it black for the fresh look
Current Car: 2002 AUII LTD 408ci Windsor, T6 S488, TH400, 2 Piece Shaft, Helicial LSD 3.23 IRS Daily: 1998 Mitsubishi Super VR-4 Legnum |
#neuteredlyfe
Next upgraded Mk1 Leopard
Less is more I think.
Let it wear then touch up as needed UK
An old detailers trick is to paint them with tyre black.
Graham South of DARWIN NT AUIII Flash Cab project (nearing completion) |
