Old 03-11-2018, 04:36 PM   #1
fobzee
Default jack stand position - mk7 fiesta st
Hi
I had to change the brake pads on my mk7 FiST the other day so I jacked the car up using the normal jack first and then used a trolley jack on the blue spots in the pic , was that a safe place ?
car looks and drives fine just want to make sure if I need to again in the future its ok
https://i.imgur.com/b3KWbS4.jpg
fobzee is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2018, 02:30 AM   #2
GTLEGEND
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Every advice post I visit where OP are seeking advice for their new vehicle, he is there and adds valuable support and advice for rectifying the problem. Really is a Legend. Technical Contributor: For members who share their technical expertise. - Issue reason: The quality of information he provides is in depth and highly valued by those posting questions.
Default Re: jack stand position - mk7 fiesta st
From the workshop manual, it should only be jacked from the side points as per the attached.
WZ Jacking Points.doc
GTLEGEND is online now   Reply With Quote Multi-Quote with this Post
Old 04-11-2018, 12:09 PM   #3
fobzee
Attachment 100361
thanks, I'll stick to them next time. Wouldn't have done any damage though? drives/looks fine
a shame there's no central spot it would make it so much easier
Old 04-11-2018, 01:41 PM   #4
GTLEGEND
Should not have if you do it once here and there, just don't make it a habit!
Old 24-03-2021, 04:53 AM   #5
phez
Where did you put the jack stands? You mention the jack points
phez is offline   Reply With Quote Multi-Quote with this Post
