Old 17-08-2017, 09:29 AM   #1
Eugene 76
Default Faulty instrument cluster temperature guage
Au Falcon temperature guage not working an cluster. New cylinder head switch fitted. How do I fix this?
Eugene 76 is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2017, 09:10 PM   #2
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Default Re: Faulty instrument cluster temperature guage
how did you go with this?
uk
Old 23-08-2017, 02:37 AM   #3
Eugene 76
Temperature guage is still not working. Can anyone suggest the next course of action
Old 23-08-2017, 03:22 AM   #4
snap0964
Check to see if you're getting temp data to the cluster:
http://www.fordmods.com/ford-technic...iagnostics-d34
If so, the analogue meter might be faulty, so you can swap it out.
snap0964 is offline   Reply With Quote Multi-Quote with this Post
Old 26-08-2017, 02:51 PM   #5
Eugene 76
Thanks for the info. I will try this next
