Hi guys;
Just a quick one. I'm installing a 12 Volt socket in the rear of my centre console and have found two screws under the drink holder that need to be removed, is there any think else besides the gear knob that have to be removed. Thanks in advance !! |
#2 | |||
You can't stop the signal
2 screws under front mat, 2 screws under cup holder, 2 screws to the floor at the rear.
Yes shifter to needs to be removed.
"Flooded it mate?"
Shifter doesn't actually need to be removed, just move it to any of D, or 3, 2 or 1 and there's plenty of room to get it over. Removed a console from an AU on Thursday arvo.
Irregular member
Don't forget to snap off the rear light cover and unscrew/push out the light bulb inside, or you might tear the cable when removing the console.
I removed a console on a parts car last night and found $2 and two pens!
2000 AU II FAIRLANE 75th ANNIVERSARY - big and shiny My hovercraft is full of eels! Movie Car Chase of the Week: Gene Hackman driving a 1971 Pontiac LeMans to chase an elevated train in The French Connection (1971). |
"Flooded it mate?"
If it has a rear footwell light! Forte, Futura and XR didnt come with them!
Hi guy's thanks for the quick reply, My au is the base model forte' so no rear console light, but what about the rear air con regester!!
#7 | |||
Register and ducts are attached to the console. It all comes out together.
There is a slip joint at the front for the duct to IP duct interface
Thank all that replyed. The reason why i wanted to remove the centre console was that i wanted to install a 12 Volt merrit socket at the back of console so as to run my engle fridge while we travel down and back to Melbourne.
I had a problem with the console that there was not enough room to fit the socket. Ended up puting the socket in the boot ( will run the power cable from the fridge through the split rear seat). Mounted the socket to a brace bracket under the rear parcell shelf. So thanks every one for your input. |
