25-02-2015, 01:15 PM | #1 | ||
KarlFromWa
I currently have a au2 xr8 with hand built tickford motor
It has a vortech supercharger and it's currently getting new head gaskets Done. Is it worth me looking into new heads while its apart? Am I going to notice any gains and if I look into new heads Will I need anything else?? Thanks it's a little new to me
DAILY: 2014 Kenworth k200.. 550hp.. 18 speed Cummins.. Topstart Pocket R/Train WORK UTE: 2001 Au2 Xr8 ute.. Vortech supercharger @ 12 psi.. Rip shift.. 19" Speedy Cheetahs.. 450rwhp FUN: 2013 FG GT Mk2 No: 1317 White.. 6 Speed Manual.. Leather.. street fighter kit .. Full custom stainless steel.. 680rwhp
25-02-2015, 01:35 PM | #2 | ||
Yeah mate definitely,some nice afr or trickflow alloy heads will get more hp,maybe some arp headstuds for more clamping force.
Post in the windsor section youll get some good answers there. |
25-02-2015, 02:21 PM | #3 | ||
KarlFromWa
Cheers mate done!
25-02-2015, 03:07 PM | #4 | ||
AFR 185cc heads part number 1492. Pedestal mount versions shoukd allow you to transfer a lit of the components from your existing setup.
25-02-2015, 05:01 PM | #5 | ||
KarlFromWa
Ok thanks. What else would I need to but to complete this?
25-02-2015, 09:45 PM | #6 | ||
Peter Car
25-02-2015, 10:29 PM | #7 | ||
With the standard camshaft that won't be a drama. You won't need any extra parts beyond what is needed for a normal head gasket change, with boost I'd recommend ARP studs over bolts. You may require new pushrods to get the lifter preloads spot on, but not 100% certainty. Use the Felpro PT9333 head gaskets, and 1250S3 intake gaskets.
26-02-2015, 11:42 AM | #8 | ||
KarlFromWa
It's got aftermarket cams Aswell. Not sure on the brand was done by previous owner.
I'm getting cometic mls gaskets, they are on there wAy atm. I'll have a look at that head
26-02-2015, 11:43 AM | #9 | ||
KarlFromWa
Also got arp studs coming too
07-03-2015, 11:58 AM | #10 | ||
Without knowing cam specs then using the AFR185 head could be a problem. The valve reliefs in the factory pistons might not be large enough for the 2.02" inlet valve.
