HI Guys
Does anybody know where I could buy black satin Acrylic paint and a flat clear for it?? not the aerosol can ones. |
![]() Join Date: Aug 2005
Check out VG Auto Paints: VG Auto Paints
Any auto body supply place wil be able to do it, its just an matting agent to normat paint. why do you want clear over? I dont believe it will add anything.
JP |
A flat clear will tend to go milky too.
You probably wont get a 1 litre of satin black off the shelf in a crash supply paint shop. I suppose your using a spray gun ??? you might have to buy 1 litre of flattening base and add it bit by bit to the black acrylic laquer then do a spray out on a matching plate let it dry and see if you have reached what flattening you want LG17 Was right about the clear going milky forget that and also like JP blue said it wont add Anything over your black satin /semi gloss paint he is dead right waste of time if that's what you were thinking of doing . also stirr the flattening base in well with a flat stick ruler if you have one forget the screw driver as a stirrer wont do sh.t
Chev badged commodores R.I.P. ![]() ![]() |
![]() Join Date: Jan 2005
You can. I bought 1 litre of satin PPG from a paint shop.
I love Holdens.... |
Well this is my first time painting the vehicle, so i opted for Acrylic and thought the clear would be better for weather / scratch protection? i could be wrong.
I'll go over to the autoshop and ask them about the flatenning agent, i thought they just sell the lacquer in a tin and you just mix it with1 part go 1.5 of thinner and spray. Just to check also with you guys should i wet sand it during coats with a 1500 / 1600 grit sand paper on a flat block or just do it after i've put down the coats and buff it? |
#8 | |||
Oo\===/oO
No. You don't sand and/or buff satin and matt finish paints...it will make it shiny!
Last warning
acrylic satin black without a clear won't last if its out in the weather a lot.
Its also painful to keep 'clean' it scuffs easy.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
MMHMM
What are you painting dash, rear spolier, if you have some knowledge and skill on 2 pack that is the best to use ,this website might help you this paint is the ducks guts http://www.dna-paints.com/ go to brochures fill out form the paint you want is Flat black 2k AGFB01 its a 3-1 mix 3 parts flat black, 1 part fx hardener , up to 10% reducer .it doesn't mark its real tough .It is ideal on rims for h/duty applications bonnets spoilers etc .the 1 litre kit is approx $150.00 hope this helps you . mick
#12 | ||
Well, I wanted to do it 2 pack paint but people say that this cannot be done without proper safety and a proper booth.
![]() There are much more colours to choose from and probably it will come out alot nicer but then I don't want my neighbours complaining, they can get abit nosey. |
