Old 04-08-2013, 10:10 PM   #1
itsposs2
Default IAC valve
Hey guys I am chasing an IAC valve for my Windsor power F250 when I searched for images on google they all pretty much look the same. Are they engine specific or or where they a standard ford part across most models
itsposs2 is offline   Reply With Quote Multi-Quote with this Post
Old 05-08-2013, 05:33 PM   #2
Bossxr8
Peter Car
Bossxr8's Avatar
Default Re: IAC valve
The only difference between them I can see is the plug end, some are straight, some are at 90 degrees. Maybe go onto www.rockauto.com and look through their catalogue. You can punch in the year, model, engine type etc and it will give you a range of parts, from factory motorcraft to aftermarket. I think it is under fuel/air listings.
