Old 26-06-2013, 10:12 PM   #1
needaXYGT
AU II XR8
needaXYGT's Avatar
Default XR8 throttle sticking - only when engine is running
A rather strange problem I have with the XR8 is the throttle sticking. Once the car has either warmed up or given a boot ful, the throttle sticks once I have released the pedal. When I put my foot down, I need to use a little force to get it unstuck, which can cause quite a rough ride!
A soon as I shut the engine down and it stops winding over, the throttle frees up and is back to normal! I removed the throttle cable and cruise control cable an tried moving the throttle arm by hand and had the same problem until the engine shut down.
I read another thread earlier about the same problem and the harmonic balancer was mentioned, so changed that as well, but no success. Iv given the throttle body a clean and a lube as well. And as a reminder, it's perfectly fine when the engine is cold or has been sitting a little while. None of the sensors on the throttle body are causing it to stick either as I had the removed when the engine was running.
I'm at the point of pulling the throttle body of and pulling it apart for a good clean. If that doesn't fix it then who knows?!
AU XR8 II ute
XD FAIRMONT GHIA 302
XA FAIRMONT 302 TOPLOADER
needaXYGT is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2013, 10:13 PM   #2
b2tf
not here much anymore
b2tf's Avatar
Default Re: XR8 throttle sticking - only when engine is running
Loose vacuum hose anywhere?
RAM 1500
Old 26-06-2013, 10:28 PM   #3
needaXYGT
AU II XR8
needaXYGT's Avatar
Not that I could see. What's the reason?
AU XR8 II ute
Old 26-06-2013, 10:48 PM   #4
Herrod Motorsport
www.sctflashtuning.com
Herrod Motorsport's Avatar
Common problem , screw the throttle stop screw in half a turn and problem solved
Australia's No1 Ford Enhancement Specialist
103 Northgate Drive
Thomastown
VIC 3074
Phone: 03 9464 5100
Fax: 03 9464 5166
Herrod Motorsport is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2013, 10:50 PM   #5
needaXYGT
AU II XR8
needaXYGT's Avatar
Thank you! Will try it tomorrow.
Ill also keep an eye out for a vac problem b2tf, thanks.
AU XR8 II ute
Old 04-07-2013, 05:48 PM   #6
needaXYGT
AU II XR8
needaXYGT's Avatar
So after winding the idle screw in a little, it made the problem a little better, but it was still there enough to **** me off, and after a little thought, I came to the conclusion that it must be an air pressure sort of thing, causing the butterfly valve closed!
So then I wet searching for a loose vacuum hose thanks to b2tf!
Turned out that the PCV hose was half hanging out.
Something I wouldn't have thought would cause such a problem, but anyway, thankfully it's gone!
AU XR8 II ute
Old 08-07-2013, 11:41 AM   #7
b2tf
b2tf's Avatar
Glad you solved it. I've had it happen to me before with the last ute and I found the hose hanging out of the back of the manifold which is a real bugger to get back in, hence my thinking it may have been something along those lines.
Now that you've fixed it, I'll give you $3k for the car
RAM 1500
