Go Back   Australian Ford Forums > General Topics > Ford Forums Central > Site Support
Site Support If something isn't working or you have a suggestion ( a nice one !! ) let us know here.
Old 20-06-2013, 12:42 PM   #1
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Thumbs up New Sub Forum - Everything Holden
Is it possible to make a new sub section "Everything Holden"
Or just "Holden"
It should go in the section Non Ford if possible
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2013, 01:08 PM   #2
FGII-XR6
FGII-XR6's Avatar
Default Re: New Sub Forum - Everything Holden
I really can't see it going well we already have enough Holden trolls who do nothing but sprout how the Ford product is inferior to the Holden without encouraging them
[SIGPIC][/SIGPIC]
Rides:
Old 20-06-2013, 01:16 PM   #3
Sorted
Sorted's Avatar
There is already a section for NON FORD but the Holden threads are not moved there :(
Yes that could also go for other manufacturers but not really an issue.
This is FORD Forums - In August the HSV will be tested and then more Holden threads will pop up.
We have a demise of the Falcon going on and lets not help the cause by having Holden Threads in the main section.
Tuned by DYNOMOTIVE
Old 20-06-2013, 01:20 PM   #4
Dash_XR
Dash_XR's Avatar
There are lots of Holden forums already, it will just mean there will be more Holden stuff filling up the new content page.
If I need any info on my Corolla I go to the Corolla forums.
FG XR6 Turbo (Manual) - 301rwkws @ 15psi
Rapid Systems Intercooler & Battery Relocation - ID 1000 Injectors - Process West Surge Tank - Venom 100 Cell Bolt On Cat - XForce 3.5 inch Catback - Plazmaman 4 inch Turboside Intake - Crow HD Valve Springs - Glowshift Gauges (Oil temp, Oil Pressure, Boost, Volt) - Malwood Opt 5 - XR50 Interior - FG2 Limited Ed 19's - Nitto Invo's
Dash_XR is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2013, 01:39 PM   #5
FGII-XR6
FGII-XR6's Avatar
I see your point but think rather than open a section that caters to Holden in A Ford forum, that all Holden threads be moved to the non Ford area without creating a Holden section. I only see dramas coming from creating a Holden section
[SIGPIC][/SIGPIC]
Rides:
Old 20-06-2013, 01:41 PM   #6
FPV GTHO
Technical Contributor: For members who share their technical expertise. - Issue reason: Sharing his knowledge of performance exhaust setups for the NA 6 cyc Barra Falcon from BA to FG.
GM and by extension Holden are a long running top competitor to Ford so I see no problem having a GM sub forum separate from the rest of non-Ford.
FPV GTHO is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2013, 02:00 PM   #7
FGII-XR6
FGII-XR6's Avatar
try something like this at any Holden forum and see what happens. the way I see it if you want Holden specific information this is not where it should be found.
if the Holden thread is directly related to a competing Ford product and the comparison line is drawn fine but otherwise go to a Holden forum and get your information
[SIGPIC][/SIGPIC]
Rides:
Old 20-06-2013, 02:17 PM   #8
Sorted
Sorted's Avatar
Yes indeed that's a better idea
Enough of the Free Advertising for Holden on a Ford Forum
It is just going to get worse from here on in
Lets move the threads to NON FORD as there is already a specific section for this...........
I will even help with the links here - these are the first 3 threads on the Pub section right now at 1.14pm 20/06/2013
http://www.fordforums.com.au/showthread.php?t=11398645
http://www.fordforums.com.au/showthread.php?t=11398511
http://www.fordforums.com.au/showthread.php?t=11397656
and then these
http://www.fordforums.com.au/showthread.php?t=11398515
http://www.fordforums.com.au/showthread.php?t=11398092
http://www.fordforums.com.au/showthread.php?t=11398523
Then if you move all the above threads then these Holden ones will pop up on the first page in the Pub
http://www.fordforums.com.au/showthread.php?t=11398275
http://www.fordforums.com.au/showthread.php?t=11398547
Tuned by DYNOMOTIVE
Old 20-06-2013, 03:10 PM   #9
karj
XY Falcon
Maybe it's just me, but I don't have a problem with some of the Holden threads being in the pub.
As far as I can tell, the pub is for "General Automotive Related Talk" and I would have thought this covered discussion of upcoming models from different manufacturers, the direction and future of the Australian car industry, etc...
It's not like people are asking technical questions about Commodores.
_________________
1971 XY Falcon 500
karj is offline   Reply With Quote Multi-Quote with this Post
8 users like this post:
Old 20-06-2013, 03:16 PM   #10
Polyal
Virtuous Bogan (TM)
Polyal's Avatar
I think most are rather relevant if its got to do with the current fortunes of both.
Some asking what a VY SS is like...next please...that kind of stuff can be moved.
  • 2023 Mitsubishi Triton
  • 1973 ZF Ford Fairlane
Old 20-06-2013, 03:58 PM   #11
Sorted
Sorted's Avatar
I haven't said delete them - for those who want to know about all things Holden find the threads elsewhere instead of the main pub section.
This is FORD FORUM not all makes and models with a sprinkle of FORD
MOST join this forum because they do or they have owned a FORD or they are a fan of FORD not cause you own any of the other makes out there especially Holden - you want to read about Holden got to LS1.com
Someone who wants to buy a Ford Google's Ford - Ford Forum comes up and 6 or 7 threads in the main section is all about Holden - what sort of message does that send..................
The latest and greatest FPV GT Rspec even has it's own section now and it has very little traffic as it's hidden away in the Forum Community Car Clubs - do the same for Holden
And the most members that will comment in this thread will be the ones who like reading about Holden as with everything the people who agree stay silent but the people who disagree voice their opinion
Tuned by DYNOMOTIVE
Old 20-06-2013, 04:08 PM   #12
Polyal
Virtuous Bogan (TM)
Polyal's Avatar
For now you are witnessesing what Ford has produced, like it or not people will back local product (most of the time) so any news about a new commy, torana etc is just that..news.
The R Spec has little traffic because how many owners are actually here?
I dont entirely disagree but the current situation is just a reflection of how the market is. I think the Ford content here heavily outweighs anything else.
I learnt, slowly, a while ago that if you dont like it then just to click on it. I dont think for a second anyone buying a Ford would care about how many threads are on a forum.
Email Ford and ask them to produce something thats good and news worthy.
Old 20-06-2013, 05:53 PM   #13
revcore
revcore's Avatar
I actually like the idea of a Holden thread. Of course I love Ford but I also love some of the older Holdens as I'm sure many others on here do too.
In order to keep it civil without the usual Ford versus Holden rivalry boiling over into a full on war it should have it's own moderator who can pull the troublemakers up before things get out of hand.
Thats just my 2cents worth.
My Ride...
2005 BA2 XR6 Magnet Ute.
revcore is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2013, 06:50 PM   #14
nstg8a
3..2..1..
nstg8a's Avatar
How many actually read the forums by section though?
I only ever just hit the 'new posts' button, and scroll through that to see if there's anything interesting. It's only if I'm looking for something specific il go through the forum lists.
Holden posts will show up just the same as now for anyone doing the same as me.
Originally Posted by pottery beige View Post
Happy mcgadget meal orphan mcboofhead
nstg8a is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2013, 07:21 PM   #15
gtxb67
moderator ford coupe club
gtxb67's Avatar
just delete the holden threads - problem solved
gtxb67 is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2013, 08:11 PM   #16
Lotte
YE-US! Wait. I don't know
Lotte's Avatar
Then you'd have to name it "general automotive talk except for Holden stuff, you've been banished to the naughty corner"
Yeah, it's a ford forum. That said, maybe we should do away with anything that has nothing to do with fords.
"Well. Apparently you're looking for a lion-snake named Harriet."
Daily: '06 BF XL Ute,Shockwave Blue, Column Shift, eGas BEAST.
Gone: 77 HZ panel van, 253, column.
The Weekender: '06 BF Pursuit, Toxic, lumpy af
Lotte is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2013, 08:21 PM   #17
Sorted
Sorted's Avatar
Yep take it to extremes lol
It's a very simple - Holden Section for Holden threads - it may end up bigger than LS1
Tuned by DYNOMOTIVE
Old 20-06-2013, 08:41 PM   #18
Fireblade
Wizard Member
Fireblade's Avatar
Isn't that what the pub's for, all automotive talk, no Holden forum here IMO.
Look I don't mind a bit of the Holden chat but I don't think it warrants its own forum.
Fireblade is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2013, 08:47 PM   #19
JC
JC's Avatar
You want Holden forum, go find one. This is Ford forum, and just because Ford Oz will stop manufacturing in 2016, doesn't mean we should suddenly embrace Holden (which is what giving it its own sub forum would do).
Ford Performance Club ACT
Old 20-06-2013, 09:46 PM   #20
FGII-XR6
FGII-XR6's Avatar
here is my issue in the first 10 threads as of now there are 5 threads on general automotive stuff (not make related) 3 that are directly Holden related and 2 that are ford related this is in a forum that is meant to have Ford as a focus am I weird in thinking this is wrong?
[SIGPIC][/SIGPIC]
Rides:
Old 20-06-2013, 09:58 PM   #21
Lotte
Lotte's Avatar
Sarcasm dude, thought that was obvious from the ridiculous name I used.
As much as I agree that as a ford forum the majority of threads shouldn't be "would this holden be a good car"; at the moment, everything that's going on with the automotive industry is pretty damn important regardless of company imho. But that's just my 2c.
Old 21-06-2013, 03:10 PM   #22
Polyal
Virtuous Bogan (TM)
Polyal's Avatar
Your answer is to then get rid of the pub, which is silly, every town needs a pub.
Old 21-06-2013, 03:40 PM   #23
TMC
SY TS AWD LPG TEZZA
TMC's Avatar
MMMMmmmmm. Who of us has got the guts to go onto a Holden forum and request a Ford forum to be added to it. I think we know the reaction we'll get.
1st car 75 XB Fairmont wagon 302C converted to 351C.
2nd car 82 ZK Fairlane 351C 4spd AOD LPG/Avgas
3rd car 97 EL Falcon police car 4L auto dual fuel
4th car 90 XF ute (work car)
5th car 06 SY TS AWD Territory Orbital LPi
6th car 95 XG ute
7th car 2014 SZ Territory TX Petrol
Fords all my life.
TMC is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2013, 10:41 PM   #24
Sorted
Sorted's Avatar
That's cause they love Holdens and have a passion for Holdens
But here in a Ford Forum most love Holden threads - no wonder Ford is out of here with Ford Fans like most in here.
They rather talk about Holdens and a random thread about Ford Closure
Tuned by DYNOMOTIVE
Old 22-06-2013, 05:49 AM   #25
burnz
VFII SS UTE
burnz's Avatar
they already have them
competitors forum: discussion and news from every brand...
and then usual threads..
GO SOUTHS
