Old 02-04-2013, 02:02 AM   #1
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
Default AU2/3 XR cluster and back seats into S2 Fairlane...?
Hi boys and girls,
I've got a lead on a leather XR8 interior, was just wondering what the go with the back seat is? I know the base and backs will bolt in, but do I have to swap bolsters over?
Also, did AU XR8's have rear headrests or not? This may make up my mind on wether I will go ahead with putting the rear seats in...
and the last question, what's the go with installing an AU2/3 XR8 cluster into an AU2 Fairlane? Do I have to change any wiring?
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2013, 09:57 AM   #2
shayne93
66 Mustang
shayne93's Avatar
Default Re: AU2/3 XR cluster and back seats into S2 Fairlane...?
As far as I'm aware and if memory serves correct, cluster should go in and plug up correct. I think its only base model (Forte, XL, Futura and XLS) that need wiring mods for the XR or Fairmont-Fairlane cluster.
shayne93 is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2013, 10:11 AM   #3
superroo
You can't stop the signal
superroo's Avatar
Incorrect on the cluster.
Problem lies with the door ajar signals. Fairmont cluster receives these individually to tell which door is open.
XR receives one signal to tell if any of the doors are open.
It can be done, but you will need to join some wires together in order for the XR cluster to know that all the doors are open. Don't do that and the car will re-lock after opening the passenger door and give you the ability to lock your keys in the car (perhaps speaking from experience here)
Also fairly certain that the trip computer doesn't play dice as well, as it doesn't receive the signals it needs from the cluster.
Old 02-04-2013, 01:31 PM   #4
rmack
rmack's Avatar
I went from to
I just changed the internals and added a Jaycar Speed Corrector.
BUILD AU II FAIRMONT GHIA
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
rmack is offline   Reply With Quote Multi-Quote with this Post
