24-02-2013, 02:28 PM | #1 | ||
After driving 2 ks in todays heat , wife noticed smoke from vents , switched aircon off. When I looked under bonnet , smelt something had burned and saw unusual wetness on the black cylinderical device in the air con system just forward of the bulkhead - left hand side. What is this black device ? and any tips on a suitable aircon workshop in SE Melbourne area - Oakleigh - Moorabbin OR ? Car is AU 1999 and has done 150000 ks and has had gas replaced about 2 years ago.
24-02-2013, 03:10 PM | #2 | ||
If it was with the air con on i doubt it would be smoke. It's likely that the evaporator is freezing up causing the air con to "snow" my car does the same thing if it has no odour it shouldn't be smoke. I'm pretty sure it is cause by the system having to much gas but i'll check at work tomorow and let you know.
24-02-2013, 04:07 PM | #3 | ||
growing up is optional
The black device is the accumulator, and will be wet during A/C operation due to condensation. As above, it could be vapour and not smoke. Did it smell like smoke? Could be a build up of leaves in the evaporator which can get hot if they come into contact with the fan speed resistor coils.
Also, does the A/C still work? |
25-02-2013, 07:42 PM | #4 | ||
Thanks for the replies.
I drove the car today , no dramas , all OK so it must have been the snow or leaves being burnt. As cold as usual. |
25-02-2013, 09:50 PM | #5 | |||
AU DIE HARD
Its condensation (fog haze) mine has done it since new and still does ,
does tend to get your attention when it first happens, seems to happen if your on recirculate and turn it off for a few minute and re start it
26-02-2013, 12:04 AM | #6 | ||
most common after we have had a fair bit of rain I find. the humidity is high and the moisture in the air turns to fog
[SIGPIC][/SIGPIC]
26-02-2013, 03:09 PM | #7 | ||
Flairs - Truckers Delight
I get mine fogging
not just a ford thing, my parents old widebody camry did it from new too
26-02-2013, 03:31 PM | #8 | ||
Former BTIKD
As Whoosha and au3xr6 said, it's moisture.
Ask anyone who lives, or drives, in the tropics.
27-02-2013, 03:36 PM | #9 | ||
Jeep/Mercedes Technician
Mine commonly does this too haha, always wondered if it was normal and now I know
The Ride FGX XR8, Silhouette, Manual, 500HP, 940NM, Tune, 71mm Pulley, KPM Intercooler, BMC Twin Air Filter |
27-02-2013, 03:50 PM | #10 | ||
I've seen it a lot. That and my sungalsses always fogging up when I hop out of the air con and into the humid air. Constantly happening today actually.
I once saw it on a plane at brissy airport on a fairly humid morning. It was while loading was taking place so the doors were opened and as the air from outside mixed with the aircon air it looked like white smoke coming out of the vents all along the inside of the cabin wall. Didn't that freak a few southerners out!
Octane BFII XR6 Turbo manual sedan. SOLD 2014 BMW S1000R 2006 Toyota Landcruiser GXL 1HD-FTE |
01-03-2013, 08:58 PM | #11 | ||
Yeah I had smoke coming from the vents of my AU falcon II today. The car has been sitting for about a week. Started up and smelt and saw smoke (not condensation) coming from the vents however there was a leaf flicking on the fan. How do I get to remove the leaf (normally just let it run for a while and it eventually works it's way loose I know). Took the glovebox off so I could access the fan, felt around but it's on the other side which I couldn't access. I have never had the problem before so I hope it's just a leaf burning!
Current Rides: FG Mk II GT R Spec Winter White #72 LV Focus XR5 Turbo Performance Blue Sold: FG XR6 Turbo Ute Silhouette, Manual, Luxury Pack, 20" FPV Dark Argent Replicas, 2 x 12" Kicker Comp Subs, 1 x 750 Mono Kicker Amp, 4 x 100w Kicker Amp, Focal Splits (Front), Focal coaxials (Rear), Audisson Bit Ten Sound Field Processor, BA XR8 Sedan, Winter White, Aftermarket Exhaust |
