Old 15-01-2013, 06:35 PM   #1
westie01
TE Cortina
westie01's Avatar
Default HAYNES / GREGORY's TE
What is the better one to use as they both have differant Info Eg' Gregorys point gap 0.304-0.406 haynes 0.012-0.016 also the Haynes talks about a 2 barral Solex carby and a V6.
Hayne's is 1977 -1983 No 426 Gregory's 1977 -1980 No 180a
westie01 is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2013, 07:10 PM   #2
Evgeni
Auto Nerd
Evgeni's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: In recognition of the many hours spent scanning information for the benefit of AFF members.
Default Re: HAYNES / GREGORY's TE
I think you will find that they are the same. Haynes usually use an imperial system, where as the gregory's will be metric based.
25.4mm in an inch.
0.012x25.4 = 0.304mm
Evgeni is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2013, 08:32 PM   #3
westie01
TE Cortina
westie01's Avatar
25.4mm in an inch.
Ok that is something I can relate to, But what about the V6 and the 2 barral Solex carby originate from.
Old 17-01-2013, 11:21 PM   #4
JimStone
Haynes is UK market, Gregory's is AUS market - different driveline options
JimStone is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2013, 12:06 AM   #5
pcman
the only manual worth using is the genuine ford manual
http://www.ebay.com.au/itm/Genuine-F...item416ec13847
pcman is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2013, 08:59 AM   #6
westie01
TE Cortina
westie01's Avatar
I know have that Repair manual WM119 for L /GL /GHIA /TE/TF Models so that is what i will use now, had it given to me with some parts I bought.
thanks everyone.
