07-01-2013, 06:35 PM | #1 | ||
Hi All,
I have been told that poverty pack AU S1's are not speed limited, as it would add extra cost to the car and all higher trim levels had limiters?? I thought that the speed limiter was only part of the ECU program? Any body able to clarify Cheers Rick |
07-01-2013, 09:48 PM | #2 | ||
LIFELONG DJR SUPPORTER
Had my SerIII XR with the cruise set at 250 on a quick blitz in NT. The XR8's coulnd't go that quick. All I can offer I am sorry.
07-01-2013, 10:12 PM | #3 | ||||
Back to Le Frenchy
You had your cruise set at 250? Hard to tell I would have thought as the speedo only goes to 240. Sent from my iPhone using Tapatalk
08-01-2013, 09:52 AM | #4 | ||
5.6L x 2 pilot
Not sure about the S1 poverty packs, but yes, the speed limiter is a function of the ECU. In my strategy and tune, there are two speed limiter parameters. VVS_SH, the actual speed limit you wish to impose and VVS_CL, a lower speed that fuel remains cut in half until this lower speed is reached. For example, my hi is 112 mph (180kph) and once hit will stay cut until it comes down to 105mph.
Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
08-01-2013, 08:15 PM | #5 | ||
As far as I know only the XR ant the T series are not limited ( they have the alloy tailshaft that will handle the higher speeds), the limiter is just programed into the ECU and can be removed with a flash tune but not recommended if you have a steel tailshaft
[SIGPIC][/SIGPIC]
08-01-2013, 09:43 PM | #6 | ||
Adam.
Both Series 1 Manual XR6's I've owned haven't had speed limiters.
2004 BA XR8, Winter White, Manual, 20's, Bluepower Custom Tune, Difilippo Extractors, etc - 241.4rwkw Build Thread SOLD 2007 BF Mk2 Winter White E-Gas Wagon, 6 Seater. 2002 AU3 XR6, Liquid Silver, Manual, Sunroof, LPG, Rebel Kit, BA GTP's, Momo Steering Wheel & Gear Knob. |
09-01-2013, 08:35 AM | #7 | ||
This was a GPS registered speed. @ 220k the speedo was reading 8% over actual.
09-01-2013, 01:00 PM | #8 | ||
Rob
My series 1.5 has a limiter, there is a module you can get to plug into the ECU to bypass the speed limiter. But there's no situation needed to go that fast.
To the OP, i'd imagine the pov pack s1's would have the steel tail shaft, so i wouldn't recommend going over 160 even if its not limited.
Supercharged Nissan 350z 280rwkw Blueprint series 3 AU V8 manual |
09-01-2013, 04:58 PM | #9 | ||
Thank all
Cheers Rick |
10-03-2013, 11:59 PM | #10 | ||
i have a s1 au forte auto and the highest speed ive gotten it to was 190km not sure how far the speedo is out that speed
11-03-2013, 12:10 AM | #11 | ||
BA/F6 BF/F6 SSV/R TTG
Will be speed limiter to 180 AU1 - AU3 all models so is EF EL. BA BF N/A 6 and 8 200. BA BF Xr6 turbo and Xr8 230 and FPV 250 and thats FACT
BA BF FPV starter button repairs. PM me. Nizpro equipped and Tuned by the BEST in the west Xtreme Ford Tuning 479RwKw Fuel limited, more pumps and power too come. F6#0507 & #0639 Pro racer and Tech expert NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below. https://youtu.be/oa4IfguGQ-A Last edited by arronm; 11-03-2013 at 12:24 AM. |
11-03-2013, 02:20 AM | #12 | |||
Cat be Still !!!
How fact is your fact Aaron................Did you right the program in to the ecu down there at Broadmedows??? Oh, thought id throw this link in for your FACT Aaron!! http://www.youtube.com/watch?v=4_EptdBA9T0
2002 AUIII XR8 n/a: 13.65@101.8mph. With Raptor Assist:..12.73@111.5mph. With ET Streets:......12.44@110.7mph, a one time fluke.........12.54@110mph back to back. With 3.9 Gears:.......12.40@112.5mph, still trying! Tune by XFT Last edited by CRAIGAU3220; 11-03-2013 at 02:26 AM. |
11-03-2013, 02:38 AM | #13 | ||
Yep sorry AU EF EL I only was referring to 6 CYL as Iam not sure on V8. Should have worded it better.
BA BF FPV starter button repairs. PM me. Nizpro equipped and Tuned by the BEST in the west Xtreme Ford Tuning 479RwKw Fuel limited, more pumps and power too come. F6#0507 & #0639 Pro racer and Tech expert NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below. https://youtu.be/oa4IfguGQ-A |
2 users like this post: |
11-03-2013, 02:40 AM | #14 | ||
Manual XR Sedans were unlimited. Auto's limited to 180.
GT 335 11.3@124.1mph 383rwkw/513rwhp Forced Performance Tuned |
11-03-2013, 10:28 AM | #15 | ||
All XRs both 6 and 8 are not limited as are T series. all others are limited
[SIGPIC][/SIGPIC]
11-03-2013, 12:09 PM | #16 | ||
The idea of that long alloy tailshaft letting go would still worry me a bit though. Would be worth inspecting for dents, deep scratches or missing balance weights if you're planning to go fast...
11-03-2013, 01:52 PM | #17 | ||
Next upgraded Mk1 Leopard
My speed limiter comes and goes and varies day to day.
But lucky for me my wife isn't in the car when I drive to work UK
11-03-2013, 08:15 PM | #18 | ||
I have a 4.0L Series III Fairmont wagon and have had it to genuine 200 on occasions when I drove in NT.
11-03-2013, 09:06 PM | #19 | |||
AU DIE HARD
Think this thread has run its limit as well
11-03-2013, 09:21 PM | #20 | ||
5.6L x 2 pilot
Tend to agree Whoosh. No value has been or can be added. Close it mate.
Stu
