'mechanically-challenged'
Just got a quick question for Ghia leather trim owners: when the woodgrain spears on the doors are removed, are there any holes or markings in the leather door cards underneath? How are they attached? I'm guessing they're screwed into the door card?
I'm after a set of charcoal leather front door trims. Would prefer XR as they're exactly as I want them, but it seems there are a fair few more Ghia ones available out there. I'm not too keen on the woodgrain spears, so just wondering if when you remove them they look like non-Ghia trims, or are there drill holes/markings underneath? If there is holes, I guess I can just re-paint the wood grain bits black to match the rest of the interior. Thanks in advance, Chris
sirchAU's Galaxy Blue Falcon S
Yes there will be holes
Resident F1 Troll
id get them painted in a high gloos black or easier yet wrap them in carbon fibre vinyl or the like
If i got them i'd be thinking of going with a matte black finish. I quite like the carbon fibre wrap look, but would want to do some other interior bits and pieces too to get it all to match better, so probably just go with the painting.
With the lights in the door, would they be a straight plug and play into the existing connectors in the doors? Cheers
Depending on your model my fairmont has the white plugs in the front drivers door loom but not the back my au xr6 also has the front white loom to but not back doors so id say take of the trim and check for the white plug
This is what I did to mine as I wanted something different.
![]() ![]() ![]() Had them done by Modicoat but you could paint them as well. Mabye this will give you some idea on what you want to do.
We salute those brave souls that enter the DARK side |
#7 | |||
#8 | |||
Going to go have a look at a pair of Ghia trims this arvo, and if they're in good enough nick, pciking them up.
#9 | |||
Yeh if it comes with the doors the lights will plug straight in failing that the newer Mazda cars have lights identical to the au door lights grab em
From u pull it :p to save a few bucks that's what I did |
Got my Ghia trims today, although ended up getting front and rear as the guy didnt want to seperate them.
Anyone want a pair of rear Ghia door trims???
