Old 21-04-2012, 01:15 PM   #1
guscorty
Default Tyres
Hello Everyone,
I have a TC Cortina with a Clevo. The motor should be a low 300hp and should run mid 12's. They are light in the rear and the car is untubbed. The Engine builder has recommended that I run a 26" x 8.5 slick. General opinion is that I should run the MT Street ET as oppossed to a full slick. Problem is, I can't get a 26 x 8.5 MT. I can get 24" which is no good for my combo or a 26"x 9.5 which is too wide for the car. Does anyone have any suggestions. The alternative is that I just go to a full slick and, as I understand I'll have to run front runners which is something I didn't want to do, one, for the extra cost and two, for the unwated attention on the street.The car currently is running radials at the front. Any help will be appreciated.
Cheers.
guscorty is offline   Reply With Quote Multi-Quote with this Post
Old 22-04-2012, 08:45 AM   #2
JG33RD
JG33RD's Avatar
Default Re: Tyres
If you get a full slick you can use light truck tyres (cross ply or rags) for the front and have them on a spare set of factory rims so you can change after racing. Otherwise it looks like you would have to pump the guards to get the et streets under there, either way you look at it, there is going to be some extra cost that will have to be allowed for. Before you do anything I would take it for a run and see how bad the wheel spin is and what time you run.
JG33RD is offline   Reply With Quote Multi-Quote with this Post
Old 22-04-2012, 09:55 AM   #3
dieseltrain79
Default Re: Tyres
What rear gears are you running ?
How wide can you fit under the back now ? What size rims do you have ?
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
Old 22-04-2012, 02:07 PM   #4
guscorty
Default Re: Tyres
I'm running 3.7 gears now. I did run the car on on cheap street tyres and the car just sat on the line and was then sideways. Wheel spin was so bad I ran a 17.7 on the first run. The second run I TRIED to take off easy and ran a 15.4. The third run I ran a 16's. It definately needs slicks or MT street et.s.
I don't think I can go wider than a 8.5.
Cheers.
Old 22-04-2012, 02:09 PM   #5
guscorty
Default Re: Tyres
The rims I have now are standard width EL Chaser rims.
Cheers.
Old 22-04-2012, 05:42 PM   #6
dieseltrain79
Default Re: Tyres
Should fit235 60 15 radial under it
Old 22-04-2012, 08:08 PM   #7
Ivan
Default Re: Tyres
We run 400Hp through 235/60/15 with no problem.
Ian
Ivan is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2012, 04:04 PM   #8
XT302
Default Re: Tyres
10.91 on 205x70x14 maxxis
http://www.fordforums.com.au/showthr...1258423&page=4
Sure the XT is heavier but making a lot more than your claimed 300hp , so a similar or greater difficulty factor....
Why don't you just go out with what you have and practice a few different techniques/tyre pressures etc , CHEAPER and a HUGE amount of satisfaction once you have got it sorted?
It's my call pizzoff, and I just called it
XT302 is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2012, 11:55 AM   #9
63futura
63futura's Avatar
Default Re: Tyres
235/60-15 MT all the way
These things are unreall on street and strip
63futura is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2012, 06:45 PM   #10
XT302
Default Re: Tyres
Have too agree with this, the car in the above link went 10.54 on them with more to come
Old 26-04-2012, 07:01 PM   #11
guscorty
Default Re: Tyres
Thanks for the input everyone.
