Old 16-04-2012, 01:53 PM   #1
Pazuzu
Default one- piece propeller shaft for Mk 2 Escort
Hi All,
I'm doing up a "wish list" of stuff I want to do to my Mk 2 Escort, and I'm wondering if anyone has ever fitted a one- piece propeller shaft to a 2- litre Escort before? If so, are there any from other makes of car that fit, or is it something I'd have to get made up by a transmission specialist? Does it affect anything else, such as the distance the car can be lowered before running into legal/ roadworthy problems? And does it provide any real advantage over the normal 2- piece prop shaft that came with the car, besides eliminating one more joint where things can go wrong?
Any info or advice would be appreciated.
Thanks,
Dan.
Pazuzu is offline   Reply With Quote Multi-Quote with this Post
Old 16-04-2012, 09:45 PM   #2
JimStone
Default Re: one- piece propeller shaft for Mk 2 Escort
One piece out f an Escort van fits straight in. Been running one in the RS2000 since 1990 with no ill effects
JimStone is offline   Reply With Quote Multi-Quote with this Post
Old 17-04-2012, 12:48 PM   #3
Pazuzu
Thanks, JimStone. Good to know it's something I can get from a wreckers easily enough.
What did you have to do to get the prop. shaft cover to fit? Does that come off the van as well?
Old 18-04-2012, 10:32 AM   #4
whooligan
whooligan's Avatar
Propshaft will bolt straight in. The single piece units were originally fitted to 1600s with the same gearbox and diff. Yokes differ from auto to manual, get the one to suit your transmission.
whooligan is offline   Reply With Quote Multi-Quote with this Post
