Old 25-01-2012, 10:08 PM   #1
martyauxr8ute
Default Re registering
The ute has been sitting now for nearly 2 years, unstarted and battery out, while I've been living and working away. I was wondering if anyone could advise me of a procedure to get the old girl back on the road. The services were all done regularly while it was driven and it didn't have any outstanding issues, except tyres, before it was parked. Any suggestions appreciated fellas.
martyauxr8ute is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2012, 10:22 PM   #2
Whoosha
AU DIE HARD
Whoosha's Avatar
Default Re: Re registering
Fresh fuel, fresh battery.Fresh oil, I would pull the IGN..fuse and crank it over for a bit to get the oil pressure up first, then plug it back in and see how it goes
Originally Posted by Riksta
Old 25-01-2012, 10:49 PM   #3
InfernoSR
Sales Representative
InfernoSR's Avatar
as whoosha said, battery & fuel and give it a run, get it warm and change the fluids.
Old 25-01-2012, 11:03 PM   #4
atec77
Fluids and battery , crank it until oil preasure shows and then replace the coil lead , check the tyres etc and low reves until it settles and the engine gets less noisy indicating oil flow , maybe 30 seconds
Just be sure no obvios leaks on the floor
Old 25-01-2012, 11:28 PM   #5
martyauxr8ute
Cheers fellas, I'll be giving it a go soon I hope.
Old 25-01-2012, 11:30 PM   #6
T3man
T3man's Avatar
Change your brake fluid too before you do too many kms.
