Old 15-08-2011, 10:54 AM   #1
V8XTasy
Default best way to get a good 0-100 time?
hi,
I'm after some advice on how to get a good 0-100kph time. I've been using a friends private driveway to do some tests. I'm finding that if I plant the throttle all the way, I just get wheel spin. So I have to be gentle initially and then build it up, but that gives me a slow start and initially the revs are below 3000rpm, so out of the power band. If I stall up the convertor to 2500rpm, again I just get wheel spin. Is there a better way to do this, or do I really need better tyres and an LSD?
I'm getting a consistent 7.4s 0-100kph on both BP ultimate and gas, using the OBD port to some diagnostics software. I have a definite dip in power around 3000rpm and need a tune, but can't justify the cost at the moment.
Cheers.
Falcon BA XT 5.4 V8 3v
V8XTasy is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2011, 11:35 AM   #2
fatcorty
Default Re: best way to get a good 0-100 time?
It's not illegal to accelerate to 100 on a freeway with a 110 limit
Last edited by SpoolMan; 15-08-2011 at 02:12 PM. Reason: You have an issue take it via PM.
fatcorty is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2011, 11:44 AM   #3
Giant
Giant's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Organising Nulon to sponsor AFF.
Best to head to the Drag Strip safer and they will prep the track and reduce the chance of wheel spin.
Try stalling up and mashing the brake pedal on take off. Drop the rear tyre pressures down to 24psi pump the fronts up to 50psi.
Stall up to a lower rpm?
Leave the handbrake on part way until out of the hole then take off.
Giant is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2011, 11:54 AM   #4
MexicanBatman
MexicanBatman's Avatar
Originally Posted by fatcorty
It's not illegal to accelerate to 100 on a freeway with a 110 limit.
you want to check that, excessive acceleration is what its called and yes they will impound you car for that...
LOL
anyway, this is being tested on his friends driveway ;) so help the fella out
what tyres you running? might help to lower the psi a little.... maybe even a small burnout to warm them up a tiny bit
MexicanBatman is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2011, 05:49 PM   #5
V8XTasy
Thanks, I'll try some of those tips and head up to my mate's farm at the weekend for another try.
Old 15-08-2011, 06:14 PM   #6
Giant
Giant's Avatar
Make sure you reset the ecu before your run because if you been crusing all the way to the farm the timing will be on the retard side of things.
Also seeing as you don't have a LSD put some weight in the boot above the right rear wheel.
Old 15-08-2011, 11:41 PM   #7
V8XTasy
cheers, I've got the gas tank in the back between the 2 wheels, not sure how much it weighs, but expect it's a fair few kg when full.
Old 16-08-2011, 02:01 AM   #8
kpcart
buy yourself a second motorcycle for $2000, and you wont have to worry about going slightly better then 7.4 seconds, you will be looking at 5 seconds and lower times.
kpcart is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2011, 08:04 PM   #9
THE CADBURY KID
If you have wheel spin issues with the single pegger the best way is to get an lsd,no two ways about it.
Single wheeler diffs are for grannys, not good 0-100km times.
And good tyres are a must,not expensive just new/newish condition.
THE CADBURY KID is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2011, 12:42 PM   #10
Giant
Giant's Avatar
Yeah I got a gas tank too when I go Drag Racing I just have 1 light on the gas and 1/4 tank of petrol to reduce the weight.
Old 18-08-2011, 11:37 PM   #11
dieseltrain79
Better way to get faster 0-100 times ???
Borrow my car ;) 3.89 @ the track .
Seriously though , forget tunes and all that , invest on some really decent tyres under the rear !!! Best bang for buck for acceleration on any car
Then start looking at tunes and such .
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2011, 11:49 PM   #12
The Monty
Just slidin'
The Monty's Avatar
Single spinners are great on the street. Ill stand by my comment that if your thinking about doing hard launching or any kind of track work, stay away from LSD's. I learnt that the hard way. Go for a LOKKA or KAAZ or something, not just a normal Factory LSD.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 18-08-2011, 11:51 PM   #13
ebxr8240
Performance moderator
ebxr8240's Avatar
Softer springs and dedicated drag shocks..
As said a good LSD and lower final drive..
A whole XR Diff centre maybe ??
If your serious buy some 15" wheels and fit some
drag radials 245X15 or so..
Daily driver GTE FG..
Old 31-08-2011, 09:09 PM   #14
THE CADBURY KID
Hes not racing competively he just wants a better 0-100 time so what i said will be fine and for the record single pegger diffs are unpredictable and just rubbish except for immature people who like to hear squeals every time they go round a corner.
