15-05-2011, 08:55 PM | #1 | ||
Hi can anyone tell me if you can fit the xr5t rear bumper dual exhaust outlet insert into a lv mk2 hatch bumper thanks cheers
18-05-2011, 07:11 PM | #2 | ||
Knows nothing. Apparently
Just looking at photos on google image search they look quite similar. I dare say that the bumpers are the same just with a different "diffuser"
I couldn't tell you if they're any different behind the diffuser though, but I do know that the floor pan is apparently different in the ST/XR5 as opposed to the boggo focus due to the ST/XR5's exhaust, or so I'm told. The boot floor is definitely higher in the 5 than the normal focus, but I've not seen the floor pan's side by side. This may come in to play. Best pics I could find: stock focus ST/XR5
2008 Electric Orange LV XR5. With dreamscience strategem SCT, K&N 57i Gen2 cold air intake for more fun and demonic vaccum cleaner noise!! 1975 Mitsubishi/Chrysler GC Galant 2-door Hardtop. 4G63 DOHC heart transplant nearly complete!
Check out the build over here |
19-05-2011, 07:57 AM | #3 | ||
Thanks for reply ,i looked at one at ford dealership yesterday ,i have a 5 door zetec and the bars look the same ,i was gonig to put it on just to make the back look a bit better cheers Mark
22-07-2011, 08:31 PM | #4 | ||
I just came across this post, I was looking at changing the rear diffuser on my 2011 Focus Zetec hatch. I went and saw my local Panel shop and it would appear that the bumper on the LVIII is a one piece unit and as such you will need to either have sections cut out of the original bar or replace the whole bar with the likes of a twin pipe one from an XR5. The trouble is that the mounting points for the bottom of the existing bar are right along side where the preferred position for a pipe outlet is so to keep it looking tidy you wouldn't be able to go much bigger than a 2.5 " tip without it looking out of place.
25-07-2011, 09:02 PM | #5 | ||
...welll, when any of you ditch your zetec bars, they have a home...
XG Falcon Ute, XE Fairmont Ghia & BA Mk II Falcon SR |
