Old 12-03-2011, 04:56 PM   #1
atomiclord
I drive way too much...
atomiclord's Avatar
Default Power Window Regulator Question
My passenger window has never worked in the period I've owned the car. I bought a wrecker (checked) regulator to replace the one in my door after cleaning the switches thoroughly.
I've just pulled the door card off and plugged the replacement regulator into the loom, but nothing happens when I hit the window buttons. Am I missing something? My drivers side window still works as normal.
AUIII Straight LPG
Done: BA XR6T Snorkel, K&N Panel Filter, EL Belt Cover, 2.5" Exhaust
To Come: Extractors, Tran. Cooler, Lowering, High-flow Cat
atomiclord is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2011, 05:07 PM   #2
Whoosha
AU DIE HARD
Whoosha's Avatar
Try running a hot wire to the unit to see if it takes power, if it does then grab a multi meter and check the wiring in the plug to find ware dead spot is
Originally Posted by Riksta
Old 12-03-2011, 07:47 PM   #3
Beer Baron
Check in the door jam for pinched wires ?
AU XLS.
Beer Baron is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2011, 08:20 PM   #4
FGII-XR6
FGII-XR6's Avatar
if either switch has a faulty interlock contact ( stops the 2 switches working against each other) the window won't work
[SIGPIC][/SIGPIC]
Rides:
Old 13-03-2011, 04:38 AM   #5
Bobman
Regulator
Bobman's Avatar
I'd say the original regulator was still fine.
Common fault is the switches on the AU models. Sometimes if you keep clicking them hard enough they'll start working again.
Regards
Bobby
Current Cars:
2000 AU2 Fairmont (2019-current)
2003 BA1 Falcon Divvy Van (2017-current)
2009 VW Mk6 Golf 118TSi (2020-current)
Previous Cars:
2003 MCX10R Avalon VXi (2017-2020)
1995 EF1 Falcon GLi (2016-2019)
1997 XH2 Falcon Van OPT20 (2016-2019)
2006 BF Fairlane Ghia (2013-2018)
2001 AU3 Futura (2010-2013)
1996 EL Fairmont (2008-2010)
2004 BA XR6 (2005-2008)
2001 AU2 Forte (2005-2006)
1988 EA Fairmont Ghia (2003-2005)
1984 AR Telstar TX5 Ghia (2001-2005)
Bobman is offline   Reply With Quote Multi-Quote with this Post
