Hi Guys
First poster here. I'm lookin to fit a amp and subwoofer while keeping the factory headunit. Can any one tell me if the stock headunit has the AV audio connections for the amp? Cheers Pete |
I drive way too much...
If you mean the RCA type outputs, it does not. Old style connections.
If you can manage it, a new head unit would probably produce better sound anyway. There is a pocket adapter kit by Aerpro to fit a single DIN size head unit in and fill in the round gaps nicely.
AUIII Straight LPG Done: BA XR6T Snorkel, K&N Panel Filter, EL Belt Cover, 2.5" Exhaust To Come: Extractors, Tran. Cooler, Lowering, High-flow Cat |
Tickford 220kw Windsor...
Does anyone know where I could get one of those Pocket adapter kits on the Gold Coast?? I wanna get one locally..
I need one for my car as Id like to turf the double din junker and fit my (little older, but still good) MP3 Pioneer headunit in there..
1972 Falcon XY GT 351 Clevo 4V Big Port, 4 Speed Top Loader Manual, Ice Blue.... 2002 Tickford AU Series III XR8 220kw Windsor, 5 Speed Manual, Liquid Silver... __________________ AU Tickford Facebook fan page.. https://www.facebook.com/#!/home.php...25060040851023
#4 | |||
not here much anymore
any good audio store should have them, fairly common thing. If you cant find one let me know, I work in auto retail on weekends and can organise you one. Remember though that with Pioneer headunits, if you install one, every time you use it the aerial will go up - even if you're not using the radio. Its just the way theyre wired.
2024 F150 XLT
351 clevo
any car audio shop and get the harness connectors, so you don't need to cut the harness
http://www.aerpro.com.au/list.php?ca...no=10&cat_sno= i used this type of harness in my ef and i have had no issues with it as i took the factory headunit out and put jvc headunit
2006 ford territory turbo stock as a rock for now 2004 territory ghia click here for pics work daily ke laser ghia RIP click here for pics Daily EF II fairmont wagon RIP click here for pics XD 351 clevo lowered click here for pics thanks to p.e.a.c.h performance at stafford http://www.peachperformance.com |
Thanks guys. I will have a hunt around this week and see how I go.. Hopefully I can snag a shop with one in stock..
(b2tf) Thanks for the tip re the ariel goin up too on the Pioneer Headunits.. Its an older headunit, I think its a DEH5750, or somthing along those lines with sub out as well as normal pre outs.. Now I know that I wont wire the eleccy ariel into the unit.. I never use the radio anyhow, and the ariel goin up even when using CD would have really badly snakes hissed me off. Sinse your a veritable fountain of good info AU wise, after I have sorted out a few bits n peices, I will have a further chat then re speaker options to suit factory mountings etc.. I know theres that other topic in this forum covering that, but I wanna run thru some more specific ideas to suit me and a budget.. Plus list the stuff I have an see if any of its usefull to use.. (misterfordfairmont) I will most likely be wiring the system up independantly of the original looms, but I will look into this harness clip too.. Cheers. With the AERPRO Pockets, and using the pioneer headunit, for the nicest looking fit should I get the 9040 or the 9140?? 9040 is just the under tray pocket part, the 9140 has a bit that goes up around where the headunit would be too..
#7 | ||||
2024 F150 XLT
EDIT I've just re-read those parts numbers and the 9140 is the one we couldnt get the headunit to actually fit through, so try it before you buy it. Aerpro's packaging is pretty easy to open without damaging it so you should be able to return it if need be.
DNA Audio also do the pockets and their stuff is pretty good so it might be worth a look: http://dnaaudio.com.au/whp703b-au-fo...c-pocket-black Also re the speakers, these spacers will open up your options a bit more: http://dnaaudio.com.au/was7565-mdf-s...ptors-from-7x5 These ones do the rear speakers in a ute: http://dnaaudio.com.au/wba069-ba-6x9-in-plastic-speaker
2024 F150 XLT
Thanks again for that.. I will check out those parts from the links above and see how I go re headunit fit.
The main aim for me sound system wise is to have a setup that at the very least is on par or a bit better than a Premium sound optioned car (which mine isnt). While avoiding cutting up parcel shelves, door trims/frames etc and finally, keep it all to a very tight budget. Iv never been one to drop many thousands on car sound as this car has a pretty nice sounding radio Weezor and my other car has a rather loud radio Cleveland.. Apologies to the OP for the thread hi-jack..
#10 | |||
2024 F150 XLT
#11 | |||
![]() Join Date: Jan 2005
#12 | ||
I have just installed a JVC stereo using an Aerpro pocket and loom kit. The pocket is an excellent fit in the fascia and the loom included makes the fitting simple.
#13 | |||
#14 | ||
stereo installed
![]() ![]() and the kit ![]() Last edited by TK-421; 08-12-2010 at 09:34 PM. |
#15 | ||
Awesome, thanks for the pics.. That looks really nicely installed..
1 Question, will that type of install work on a tilt down front face type headunit?
#16 | ||
Lost Boost Gained Class
if u wanna keep the standed head unit and standed everything then i have a Word for u
Stinger SGN11 this will alow you to add a sub to the standed hedunit i have the same pocket as IntechAU has but i have a flip down dvd head unit
2006 BF Fairmont Ghia
2001 AU Falcon |
