02-02-2010, 04:50 PM | #1 | ||
Guys DON"T ever loose the security wheel socket that comes with the car because there are NO replacement available especially for e.g. you have a flat between Sydney & Melbourne the car needs to be towed and have the nuts drilled off! is there another way to get them off ? :
apstar |
02-02-2010, 04:54 PM | #2 | ||
Now XR5hatch!
02-02-2010, 05:00 PM | #3 | |||
apstar |
02-02-2010, 05:04 PM | #4 | ||
WAGONE
are they aftermarket ones?
I know when i bought saas ones they come with a code for that particular key, i just got a replacement one through autobarn for $10 but yours must be different??? i know a mate that smacked his loose with a hammer and chisel but he had easy access to the front of it.... yours look like theyre a bit recessed
Car Builds: EF Turbo Track Hack AU II XR6 sedan AU XR Sportsman Wagon AU Falcon.com page |
02-02-2010, 08:29 PM | #5 | |||
Now XR5hatch!
Signup. Its free and they don't send you garbage. Or just go here, this is the order form. You'll need the key code that came in your cars user manual to order the replacement. https://www.wheellockkeys.com/homepa...bestellung.php McGuard manufacture the locknuts for ford. I've got two sets of McGuards on my wheels, they are the best going. So if you don't have the key your in deep. |
02-02-2010, 08:35 PM | #6 | ||
I had my huards rolled by some clowns in the city and they stripped the head on my lock nut. It took me 2 hours to drill and chisel the damn thing off. I was tempted to drive back to the dealer and throw it though their window.
HendrixHC --------------------------------------------------- 1966 Mk1 Cortina 1982 XE Falcon 1978 XCGS Falcon 1993 XG Ute 2015 FGX XR8 |
02-02-2010, 10:24 PM | #7 | |||
apstar |
02-02-2010, 10:33 PM | #8 | ||
I once used an old socket, it has to be smaller then the lock nut hit it on with a hammer and then simply grab the ratchet and take it off.
You will ruin the socket but it gets it off if its an emergency. |
02-02-2010, 10:46 PM | #9 | ||
Fixing Ford's **** ups
Most locknuts can be removed by bashing a socket over it and using a ratchet, remove it. Done a heap in the past and probably do a heap in the future.
Key lock style. A paperclip, bit of wiggling and wala, no more locking mechanism.
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises. Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone |
02-02-2010, 11:54 PM | #10 | ||
Maybe this photo helps the shape is unique to each car nobody else socket will fit mine and you cannot get an replacement if lost YOU ARE STUFFED!!
apstar ps I might take then off and replace with standard nut I can see what's going to happen one day :togo: Last edited by apstar; 03-02-2010 at 12:02 AM. |
03-02-2010, 02:23 AM | #11 | ||
A 21 or 22 MM hexigional socket, with a FBH and extension bar. Goodbye locknut for good.
All that's required is to make sure the socket will be a tight fit prior to bashing with the FBH. Then guaranteed, locknut will be gone for good and rims will be scratch and dent free, providing you're not a lousy shot
03-02-2010, 09:21 AM | #12 | |||
03-02-2010, 09:32 AM | #13 | ||
Surely you could drill a hole in the centre and bash in a large square easy-out?
"All my life, I have searched for a car that feels a certain way. Powerful like a gorilla, yet soft and yielding like a Nerf ball. Now, at last, I have found it" Homer. J. Simpson....... EF Project, SIX666 - ITB's + Turbo |
03-02-2010, 03:08 PM | #14 | |||
Now XR5hatch!
Isn't your post saying you have lost the socket to remove the locknuts??? If so, order a new one from the link I posted using the "locknut ID code" provided with your car. It is a unique identifier that is paired to your nuts, McGuard will have the socket ready to go. If your saying you lost the actual locknut, just buy a newset from McGuard. Either scenario McGuard will help you out. I know it works because I've ordered a set. |
03-02-2010, 07:49 PM | #15 | |||
Firstly, looking at the picture, it appears to be an aftermarket locknut. So the problem then comes to, what brand of locknut is it, so another locknut key can be ordered. If you can't findout what brand the locknut is, then you've got to remove it, before you can put a new set on. Correct? Or am I missing something here? NZXR6. The socket I use is an elcheapo Repco one. Removed a fair few with that socket and it's still good for a few more. All that's needed is for the teeth inside the socket to grip the outer edge of the locknut and it'll come off.
03-02-2010, 09:28 PM | #16 | |||
apstar : |
03-02-2010, 09:54 PM | #17 | ||
I'd expect that Ford have a record of the locknut code for each car supplied with alloy wheels. But it might be worth ordering a spare and keeping it somewhere safe just in case.
It's worth a look at the McGard website: http://www.mcgard.com/Home/AutomotiveProducts I really would love to know if the socket trick works with their "restricted chemistry" hardening, but I'm not prepared to risk damaging a $125 set of lock nuts! Anyway, I just see lock nuts as a deterrent against the Really Stupid wheel thieves who think that Euro Ford alloys are worth stealing.
04-02-2010, 01:45 AM | #18 | ||
The only downfall with expecting Ford to keep records of all cars supplied with locks is, some aren't fitted with locks when they're at a Ford dealership. Cars can be traded at other dealerships, minus locks and those dealerships could fit them, or the owners could fit them and then trade the car in. Rather impossible, don't you think?
Ideally, the best solution is as APSTAR has said. Record the number of the key and most importantly, the manufacturer of the locknuts. Saves headaches all round
04-02-2010, 10:25 AM | #19 | ||
Giddy up!
Good advice here. Weekend comes, I'll be noting the wheel nut number. I'll be writing it down somewhere in the car and also in the Mondeo file at home.
I think I have two of these nuts, which means I'll be taking one out and putting it with my spare key. The other will stay in it's cunning hiding place. When they rotated my tyres at the last service, I don't remember telling the dealer where the key was hidden...
Current: June 11 built Titanium TDCi Territory, Edge, side steps, mud spats, bonnet protector, tow pack, full tint. Nov 10 built XR6 Sensation. Previous: Oct 07 built Mondeo TDCi hatch, Stardust Silver, bluetooth, leather, tow pack, sunroof. |
04-02-2010, 11:29 AM | #20 | |||
Deep Impact Blue GT manual (EVRTON) Rear spoiler, black OTT, tints, locking nuts, front sensors. |
04-02-2010, 11:30 AM | #21 | ||
I had R2D2 in for a service and they forgot to put on a lock nut. I went back the next day and they said they couldnt order a new nut but had to order a full set, $245 is what they quoted. They paid for it. Thank goodness.
Sold - Thunder XR5 2008 Now - BF Falcon RTV |
04-02-2010, 12:18 PM | #22 | |||
Giddy up!
How could I tell? Those on the front were cleaner than those on the rear. I'll have to have a look tonight if the lock nuts are still there.
04-02-2010, 07:51 PM | #23 | ||
Now XR5hatch!
Ford does have a master key that fits all nuts.
You can also request this to remove your wheels if you loose your socket. As far as I know the master key is in melbourne only. Your dealership may have it? |
09-05-2010, 11:40 AM | #24 | ||
I had my car serviced yesterday and they stripped the lock nut...blamed the tyre company who recently fixed my flat -said they overtightened it. Looks like they damaged the pattern of the lock nut, it still fits on but there's a bit of play.
Their solution is to weld a normal nut onto it and use that to get it off. Haven't done this yet...so if I get a flat in the mean time I am stuffed. When they do that I'll just leave a normal nut on...who the hell would steal Mondeo rims?? |
09-05-2010, 01:09 PM | #25 | ||
Now XR5hatch!
People steal anything these days...
The McGuards are ultra high security, but can be damaged easily by careless tyre fitters. I remove all lock nuts and replace with regular wheel nuts before going for servicing and tyre replacement. I then refit the lock nuts after they have done their work. This way Im guaranteed not to have to worry about careless people stripping the locknuts which are extremely hard to remove once damaged. |
09-05-2010, 06:09 PM | #26 | ||
Locknuts aren't hard to remove by any stretch of the imagination. If I had a dollar for everyone I've removed, I'd be retired by now.
There are locknut removers available these days. They're a similar design to an easiout. They're in a socket form and they go over the nut gripping the metal when it's being undone. Another way, is belting a socket over the end of it and undoing them.
09-05-2010, 08:05 PM | #27 | ||
BF XR6
my locking key snapped in half when i was putting my wheels back on, it took my local tyre shop 10 minutes and $15 to knock a socket over them and get them off.
i didnt bother replacing them because if they can get them off in 10 minutes with a cheap socket set whats the point in having them
BA Falcon XR6 [JS92WA]in Winter White, 6 Speed ZF - BF Tail Lights, Pacemaker Twin 2.5" catback DBA Gold Series Rotors, 5% tint >>ITS BACK - The REBUILD IS ON, BF 2 Ghia 3v V8 5.4L, Full Fairmont Ghia Interior with FPV GTP seats,Boss Bonnet,BF Front End, DJR 302 Rear Wing, BF steering Column with BF ignition and FG keys, << 2010 FG Falcon XR6 [XRLNT] in Lightning Strike, 6 Speed Auto - 15% Tint, Ipod, Bluetooth, Climate Control, custom plates, DJR 302 Wing |
09-05-2010, 08:59 PM | #28 | |||
3..2..1..
09-05-2010, 09:56 PM | #29 | |||
Now XR5hatch!
The McGuards fitted to the mondeo and focus XR5 are ultra high security. They are hardened steel, extremely hard to drill. And the outside of the nut is not part of the actual threaded nut, so it spins independently if you try to belt on a socket. These locknuts aren't on the falcons, so most people would have seen them before. |
10-05-2010, 06:42 PM | #30 | |||
ie I had a Ford Service person tell me it is impossible to take the key fob out of the car with the engine running. Had to explain to them about that whole "keyless start" thing. |
