Old 14-12-2009, 08:38 PM   #1
xbcool
dazed&confused
xbcool's Avatar
Default drag slicks
I recently bought a set of slicks (radials) and one of them has a slight leak ,its not on the tread or on the side wall but more in between.
the place that fitted them (not the supplier) said they could put a tube in but we are not sure if its a good idea or not.
anyone had experience in this area.
steve
ban frangipanis
beauty is only skin deep.
ugly goes all the way to the bone.
xbcool is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2009, 08:59 PM   #2
naughts
Hmmmmm Mulberry....
naughts's Avatar
Unless you turn the tyres on the rim, then its no issue
naughts is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2009, 09:15 PM   #3
xbcool
dazed&confused
xbcool's Avatar
yeah the car runs 12s and only leaves the line at about 2ooorpm so I don't think its gunna turn them.
ban frangipanis
Old 14-12-2009, 09:21 PM   #4
naughts
Hmmmmm Mulberry....
naughts's Avatar
My mates car runs 10's and has a tube in one. He puts screws in to stop tyre turning.
Old 14-12-2009, 10:30 PM   #5
xbcool
dazed&confused
xbcool's Avatar
thanks for your help naughts ,I reckon she'll be right.
steve
ban frangipanis
Old 14-12-2009, 10:58 PM   #6
northey
I guessing you've had a good look inside the tyre to find out why it leaks.
If I read this correctly and it's on the edge of the tyre where the tread becomes the sidewall it needs to be looked at carefully. There can be a lot of stress on that part of a tyre.
Tubes are ok but check first.
northey is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2009, 11:08 PM   #7
xbcool
dazed&confused
xbcool's Avatar
yeah all looked good on the inside and it was only a small very slow leak
ban frangipanis
Old 15-12-2009, 09:46 AM   #8
Whoosha
AU DIE HARD
Whoosha's Avatar
Just a tip if you put a mark on the side wall at the air valve you should be able to see if it is spinning the rim on the tyer. Kevs full slicks on draglites (11s man. & big right boot,qwick left foot)spin nearly 1/2 a turn after abig wekend out :
Originally Posted by Riksta
Old 15-12-2009, 11:25 AM   #9
xbcool
dazed&confused
xbcool's Avatar
1/2 turn geez that heaps, spose it's got a fair bit to do with the manual but a great tip in using a bit of texta
ban frangipanis
Old 15-12-2009, 06:30 PM   #10
XT302
Block turns both radials on the rim, obviously would be better if didn't turn them.
http://www.fordforums.com.au/showthread.php?t=11258423
Stick it in the bath tub, see where it is leaking from?
It's my call pizzoff, and I just called it
XT302 is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2009, 11:58 PM   #11
TruBlu351
3 Pedals R Better Than 2
TruBlu351's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Has given endless help in the cleveland section over the years. Knows his stuff and happily tests on the track and gives no fuss results.
Maybe some of the special white grease the tyre fitters use on the beads might seal things up next time you try refitting them? But then again, that might allow the tyres to turn on the rims more?? OR, if you identify where along the rim/tyre bead it is leaking from, just lube that small section.
I'd prefer not to run a tube.
Radials are known to leak sometimes, just some more than others.
XE Falcon - Under Construction
434 E85 Lawn Dart underway
TruBlu351 is offline   Reply With Quote Multi-Quote with this Post
