Old 06-11-2009, 08:04 PM   #1
Windsor220
Now Fordless
Windsor220's Avatar
Default Rear shock mounts
No doubt been a lot of talk about these over the years. My question is where is the best place to get them? Ford will charge a heap Im guessing.
Old 06-11-2009, 08:08 PM   #2
blackers10
blackers10's Avatar
ford.. $90 ea from memory
I know some of the T series boys were putting some R&D into some heavy duty/performance type items using pillow ball type mounts or somthing along those lines
Old 06-11-2009, 11:40 PM   #3
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
haha windsor220, your DP reminds me of this:
http://3spades.net/dump/celica.jpg
Old 07-11-2009, 01:20 PM   #4
Windsor220
Now Fordless
Windsor220's Avatar
You saying my car looks like a Celica?
Old 07-11-2009, 03:58 PM   #5
Papa Smurf
Papa Smurf's Avatar
Ford ones are $113.50 each, part numbers AU2 5T121B and AU2 5T120B.
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2009, 02:50 PM   #6
madmelon
Nolathan part number 44022, $179 a pair from Repco. They're an order in only item and would have a freight charge of $10-$20 depending on what the person serving you feels like. Would have to ring up or visit during the week to determine availability- I spent 20 minutes going through the national store catalogue system today and as far as I found no store has ever had them or is likely to.
madmelon is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2009, 03:08 PM   #7
Windsor220
Now Fordless
Windsor220's Avatar
Would nolathane ones be recomended? They are harder than the factory rubber ones so will probably break quicker
Old 08-11-2009, 05:55 PM   #8
T3man
T3man's Avatar
I wouldn't use nolathane in that area - the current (upgraded) ones that Ford sell are your best option. They last far better than the originals and there is no risk of bump-crash through the mount that you may get with nolathane.
Old 08-11-2009, 09:29 PM   #9
madmelon
I don't know. They may be stronger too but all I know is the part number and the price.
What do you mean by "bump-crash"? The problem with mounting a shock with rubber is that the shock becomes less effective the softer the mount. Ideally, the mount would be solid so that the shock can actually work as it is designed to- supplying a force relative to velocity. Having them rubber mounted adds an additional spring component that can screw around with things. Unfortunately a solid mount would transfer considerable noise into the chassis so the rubber/etc mounts are necessary.
Maybe the Nolathane ones aren't ideal for everyone but for people using their cars for track work or those who are extremely fussy about suspension control on the road, the Nolathane may be a better option.
I wasn't aware that Ford had come out with an upgraded part...
Old 09-11-2009, 12:30 AM   #10
T3man
T3man's Avatar
By bump/crash I mean every time you hit a bump the shock (impact) transfers to your body like a crash effect. Nolathane is too rigid IMO and will cause this severley in the top shock mount situation. I'm talking about road use not track use. Yes, for track use you want a solid mount - as long as that mounting point can transfer the shock load without breaking something - like you said. IMO rubber is the better option here because nolathane doesn't take kindly to compression shock and will crack prematurely compared to a good quality rubber mount. There are places to use nolathane and this isn't one of them.
Ford upgraded the part about two years ago.
Old 09-11-2009, 12:49 AM   #11
grandpa_spec_F6
AFF Whore
grandpa_spec_F6's Avatar
Im about to throw new shocks and SL springs in the rear, would you guys advise to change the shock mounts while im at it? She's done nearly 170k.
Favorite Quote:
Originally Posted by Big Damo View Post
My GMC Sierra is banned under Victoria's high powered vehicle laws, and its a 4082kg apartment complex on wheels.
Current Ride: Not a falcon, the struggle is real
grandpa_spec_F6 is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2009, 01:05 AM   #12
madmelon
I always try to minimize total cost by getting everything done while stuff is already apart. You may not need it though- could be just fine. There's a thread somewhere of how to change which would give you an idea of what to look for if you wanted to check the condition of them before doing anything.
Old 09-11-2009, 07:27 PM   #13
Windsor220
Now Fordless
Windsor220's Avatar
Droppped into Titan Ford today. They said they were $130 each. Trade price were still $100. A bit pricey.
Pedders dont do them. Might try a couple of other joints tomorrow.
