Old 23-07-2009, 09:23 PM   #1
Ralliart
2011 A New Fresh Start
Ralliart's Avatar
Exclamation Car Services
Hey guys, Its That Time of Year Again Car Service Time, just wondering does anyone Know any good Placings for car services , I'm looking to spend $100 on my next service its For a 150,000 For a Mitz Magna I've looked in my Car Service Manual its Not a big service only Minor One , any help will be well appreciated Thanks
Erik
Facebook
Google+
Ralliart is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2009, 01:00 AM   #2
Buzz Box
Wheel Wally
Buzz Box's Avatar
Hope your handy with the tools lol
Currently:
2006 Ford Fairmont Ghia BF
1999 Land Rover Discovery Series II - "Thomas The Tank"
Previously:
2009 Ford Focus - "The Bubble Car"
2002 Ford Futura Wagon - "The Big White Wagon"
1996 Ford Falcon - "Ophelia"
1975 Jaguar XJ6 - "The Beast"
Buzz Box is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2009, 03:24 AM   #3
daikin
last time i tried cutting cost and doing mine at the local kmart was a disaster, got the car back worse than it originally was (e.g. alignment off). better off doing myself or heading to the professionals.
daikin is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2009, 07:39 PM   #4
Ralliart
Ralliart's Avatar
ive checked my car service booklet for this service its only a minor service so i'lll be getting done @ a local service dealer, just Oil and Filter needs replacing i'm not going spend $100+ just to get them things done.
On another Note, My Family has Finally Jumped Ships, They are Getting a Ford Falcon as Their Next Car, if everything goes well tomorrow, we will have a brand new Falcon xr6, they haven't Had a Falcon since i was Born, really hope they get thr correct amount of Money for trading in the Vw Jetta.
I'll be creating a new thread once i know that my parents will be getting the xr6 Falcon.
Facebook
Google+
Old 24-07-2009, 08:32 PM   #5
Spaniard
Spaniard's Avatar
I think you would be hard pressed to find a professional that would give a service for $100.00 although Midas do give $139.00 services and check over the car also.
Midas link...
Spaniard is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2009, 08:35 PM   #6
Mongoose
Can't go around corners
Mongoose's Avatar
EDIT: no wait, im thinking of the 135,000. My bad only oil and filter. If your handy with a spanner you could do it for under $50. Not too sure on who can do it for that kinda price down there but make sure they use a genuine sump plug "washer" as the genuine's use a little rubber 'O' ring. And they tend to leak when used with a metal type.
Quote from Jeremy Clarkson in the Top Gear Vietnam special:
You know when we got to the 16th century, I think we turned left when we should have gone right, now were in the 13th century!
Mongoose is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2009, 08:42 PM   #7
Ralliart
Ralliart's Avatar
Originally Posted by Mongoose
150,000 in a magna? i think you will find is is a "major" service, depending on wether its a 3.0 or 3.5L it should be Oil+filter, Air filter, front spark plugs, Brake fluid and coolant...
My Car Is 3.0L
The 150,000km Service
* Flush Brake Fluid
* Check Coolant % - Refer Specs
* Flush Coolant - 4 Litres - Glycol
* Road Test (Check & Report on Engine/Trans/Brakes/Steering/Suspension)
* Inspect Seatbelts (Operation)
* Inspect & Lube All Locks and Hinges
* Inspect Lights/Washers/Horn/Indicator Switch/A.C. Operation
* Inspect and Inflate Tyres (Including Spare)
* Inspect Battery (Levels/Security/Clean Terminals)
* Inspect Air Filter
* Inspect/Adjust Drive Belts
* Inspect Cooling System (Levels/Hoses/Leaks)
* Inspect/Top Up all Fluid Levels
* Change Engine Oil & Filter
* Inspect/ Top Up Trans. & Diff (Levels/Leaks)
* Inspect Underbody (Security/Leaks)
* Inspect Exhaust
* Inspect Steering/Suspension/Engine Mounts
* Inspect Brake Pads & Discs Front & Rear
* Inspect Power Steering Hoses (Leaks/Condition)
* Inspect CV's & Drive Shafts (Joints/Boots/Leaks/Damage)
* Reset Service Lights
Parts
Oil Filter - 1 unit(s)
Flush Brake Fluid Material - 1 unit(s)
Glycol Coolant - 4 unit(s)
Engine Oil -- Refer Specs. - 4.3 unit(s)
Facebook
Google+
