Old 01-04-2009, 02:53 PM   #1
Fredo
Nice kitty . .
Fredo's Avatar
Default Tail Light Issues
This is driving me crazy guys!!
Can anyone help?
Right rear indicator stops working - Pull housing out - All okay and indicator starts working fine.
5 Minutes down the road - Right rear indicator stops working - Pull housing out - All okay and indicator starts working fine.
. . . And so it has been going for 4 days now.
I've jiggled, twisted, squeezed the cables and fittings while the housing is out of the car but the little orange bu66er works just fine. 5 minutes down the road . . . no worky.
Any suggestions folks?
Fredo
Just remember, amateurs built the Ark and professionals built the Titanic!
Late 2005 LS CL, 5spd Manual, 5 Door, Titanium Grey
To Do List:-
:- Using 95 RON Fuel (DONE -easiest upgrade of all) :- XR5 Springs (DONE) :- Lower air box removal (DONE) :- K & N Panel Air Filter (DONE)
:- 2.25" Cat Back (DONE) :- DBA Brake upgrade (DONE)
Fredo is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2009, 06:34 PM   #2
819_FLY
819_FLY's Avatar
If it works each time you pull it out and jiggle the globe around, if it has a negative tab that springs against the base of the globe, pull the globe out and bend the tab down a little bit further into the housing, then reapply the globe and it should be enough tension to keep the globe working, however be careful not to connect positive with negative otherwise zappage can occur.....
I drive my American Owned, German Inspired, South African Built, Australian Bought, European Styled, English Powered car. I might have missed something somewhere... 08' LT Ford Focus CL
Check out 819FLY!!
819_FLY is offline   Reply With Quote Multi-Quote with this Post
