Old 10-02-2009, 08:01 PM   #1
Whoosha
AU DIE HARD
Whoosha's Avatar
Cool No Codes.......
Well the on going saga of number 2 sons S111. SR continues. got the ball joint sorted, only to have a ongoing problem with engine to re appear. Seems every time the weather gets beyond 35c it decides to run rough as and revs up to 2500 then just dies only to burst back in to life at 250rpm, makes for interesting driving in peak times : Replaced the fuel filter, checked the usuall sensors, went for a lap around the block only to split a radiator hose : fixed that only to find the surging.. missing is still there .ran it down to the workshop to get the scan tool read out only to find not one code came up :sm_headba Needless to say as its cooler now the thing runs fine up to the rev limiter Ware to next is my question ?, thinking may be a fuel pump hissy fit in the heat, but at $200 + for a new one I'm open for any other ideas first _
Originally Posted by Riksta
Old 10-02-2009, 08:04 PM   #2
RG
Back to Le Frenchy
RG's Avatar
I'll bring the old stocko pump from the XR down to you this weekend, see if that works.
Old 10-02-2009, 08:11 PM   #3
Racecraft
they call me Tibbo
Racecraft's Avatar
coil pack is breaking down in the heat.. small cracks etc expand and render it useless
Old 10-02-2009, 08:56 PM   #4
Froudey
Froudey's Avatar
My XR6 is doing the same thing, i have replaced the plugs, fuel filter, air filter, had the isc cleaned and alike, my car runs fine then after a long drive or in the heat it runs and then sometime shuts down.
Froudey is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2009, 09:16 PM   #5
Laminge
Cuban... nothing like it
Sounds like a lead is shorting out, have they been changed, what about electrical wires, traced those for wear
What racecraft said!
Laminge is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2009, 09:32 PM   #6
Whoosha
AU DIE HARD
Whoosha's Avatar
I'm thinking Tibbo might be on the money
Old 10-02-2009, 10:21 PM   #7
chrispie123
you have said you have replaced the fuel filter have you cleaned the sock on the base of the fuel pump in the tank?
chrispie123 is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2009, 10:50 PM   #8
Laminge
Another good point, though surging is the usual sign for this fault, worth the try though
Old 10-02-2009, 11:20 PM   #9
Froudey
Froudey's Avatar
there is a sock???
Old 10-02-2009, 11:51 PM   #10
RG
Back to Le Frenchy
RG's Avatar
Originally Posted by Froudey
there is a sock???
There is a sock, it's the pick up.
Old 11-02-2009, 08:50 AM   #11
Foggy
Mine was stalling in hot weather as well and after fitting a new pump and sock no problem.
Foggy is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2009, 01:16 PM   #12
Whoosha
AU DIE HARD
Whoosha's Avatar
Ta mate ..just orderd a new coil as well so we shall see how we go
