Old 27-01-2009, 11:13 PM   #1
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
Default AU Intake upgrade - what's the deal?
Ok, well I've been reading some of the archived threads about this subject and the scale of different opinions has left me quite confused....
I will definately be putting on a BA XR6T snorkel & obligatory K&N filter, and maybe even the airbox lid from an EF (apparently it flows about 20% better than an AU and it has larger outlet hole) but now I'm talking about from airbox to throttle body, just to make absolutely sure nobody misunderstands me....
What's the best way to upgrade this? Considering that I'm not going for a 12 second car or anything like that......just want my daily driver to have some more grunt and be more responsive so I can have a little more fun with it......but I don't want to lose any torque either.....
Firstly, the upper intake tube: It seems that some have switched to a BA upper tube, where others have left the AU setup. Is one better than the other?? Or is it more about looks?
Secondly, the airbox to upper intake pipe: I have noticed on many workshop threads that people have replaced the stock pipe with a 3" stainless steel or silicone pipe....what benefit does this provide, and is it at the expense of torque?
I saw this post from JC:
Originally Posted by JC
G&D use the factory AU piping on their air boxes. I think that says something for the flow of the standard tube. Bigger isn't always better - just bigger. The bigger tube may reduce airspeed, therefore affecting torque. Yes, you may end up with 1 or 2rwkw more PEAK power using a bigger intake tube, but less actual power overall.
Is this right??? If this is the case, why fit a 3" pipe??
I'm just trying to understand a bit more about the subject before I start modding - I don't want to go and get something I will later regret....
Thanks for your help guys!
Dave
Old 28-01-2009, 02:10 AM   #2
brad`
The Monty
brad`'s Avatar
as far as i know the BA upper intake, and the stainless steel ones are more for show, diffrent people have reported that:
were the BA intake sits gets hotter because it sits over the engine its self more in an AU and with the stainless steel its more looks then anything same deal being steel it heats up more.
may be wrong so dont go entirely on my words im sure in the morning JC, Blueprint, russel will correct me if im wrong
cheers
brad`
brad` is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2009, 03:28 AM   #3
bloggs24
go get yourself a good pod, i highly recomend 3A Racing pod for price and quality, got mine from autobarn, and get yourself in on the airbox groupbuy in the groupbuy section, however im not sure how effective they are with the triangle headlights.
bloggs24 is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2009, 11:34 AM   #4
autickfordfairmont
Tickford Equiped
autickfordfairmont's Avatar
From what I have seen/done/read about on here, the XR6T snorkle and K&N filter is all you really need to do. Next step is to look at the other side of the engine, and look at sports exhaust (if you dont already have one). Doesn't matter how much it breaths in if it cant breath it back out.
An XR6T snorkle, K&N filter and sports exahust (2 1/2 inch, high flow cat & extractors if you can) will give the best results by far. You dont need to go changing intake pipes to larger ones unless your pumping some serious air through it by way of a turbo or supercharger.
The EF air box lid I havent tried myself but have read alot about it on here & other sites so that would help aswell.
Also de-burring the inside of the standard intake tube with a dremel to make it smoother apparantly helps aswell.
Another thing to do that i have seen done & tried myself is to make a small scoop (out of thin sheet aluminium, plastic, whatever you have really) that attaches at the front of the snorkle and goes down behind the grill to help "scoop" up a bit more air into the snorkle.
Just my thoughts.
Col.
Genuine Tickford Equiped 1998 AU Fairmont
Mods: ....... Dash mat & Air Freshener, does that count as a mod??????
Sports Exahust, Tickford Intake Snorkle, K&N Filter, NGK Plugs, Top Gun Leads
TS50 Front Bar with Fog lights, TS50 Rear Bar. Injected LPG System,
autickfordfairmont is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2009, 11:42 AM   #5
autickfordfairmont
Tickford Equiped
Scoop thread - http://www.fordforums.com.au/showthr...=scoop+snorkle
Old 28-01-2009, 11:45 AM   #6
RG
Back to Le Frenchy
RG's Avatar
I would get in on the airbox group buy, for the money you can't do better.
Old 29-01-2009, 12:27 PM   #7
MGGT RAA
AUII XR8, BA XR8 290 UTE
MGGT RAA's Avatar
That little scoop thing is a geat idea... im making one up at work today. Did ya notice any difference in engine temp? obviously it will restrict air flow to the radiator a tad yeah??
AUII XR8 220 Build : Blown 380HP 810NM - http://www.fordforums.com.au/showthread.php?t=11253752
BA 290 XR8 Ute Build -http://www.fordforums.com.au/showthread.php?t=11271242
MGGT RAA is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2009, 01:36 PM   #8
broken_suave
broken_suave's Avatar
I had one in for a while, no difference in engine temp at all.
One thing I noticed was that, oddly, the fuel consumption was up ever so slightly with the scoop. However, response was improved in all ranges, but showed its colours in 80km/h+ overtaking.
My theory is that if more air is going into the engine, there may be more fuel required to mix with it. Can anyone confirm that?
*EDIT* I should mention that fuel consumption was actually lower at consistant highway speed, but there was a tiny increase in around town driving.
05 BF XR6 ZF 6spd - Stock for now
Previously:
98 AU Futura 4.0 - Wildcat Extractors, 200cpsi Stainless Cat, Custom 2.5" Mandrel Bent Exhaust, Tickford Snorkel, Fram 'Airhog' Panel Filter - Daily
79 P6 LTD Silver Monarch - Project
broken_suave is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2009, 02:36 PM   #9
MGGT RAA
MGGT RAA's Avatar
Well i do about 90% country/highway driving so im gonna see how it goes for curiosties sake.
It wasnt a massive increase in consumption around town yeah?
Old 30-01-2009, 11:15 AM   #10
broken_suave
Not really no, a tank probably lasted around 20 kays less than normal, give or take.
My design seems to be a bit different to a lot of others I've seen on here, perhaps thats the reason. Others have reported better performance around town, whereas mine was only really useful above normal around town speeds. Maybe even small things like an 'Air Deflector' (as I prefer to call it) will vary noticably with changes in design.
I plan on having my design made up by a fabricator, perhaps even selling a few.
Previously:
Old 30-01-2009, 12:10 PM   #11
MGGT RAA
MGGT RAA's Avatar
i put mine on yesterday and drove it to work this morn... It had better pick up at over 70 k's, feels a bit punchier when ya sink ya boot into it too. Nothing massive but there is a difference.
I Havnt seen that many of them so i made mine from an idea of what i thought it'd look like. Used 1mm Ali plate and bassically bent it into a ski jump haha. gonna take it out this arv and play with it a bit more, i reckon i can get a bit more flow through there.
Old 30-01-2009, 01:19 PM   #12
broken_suave
With mine, I cut a small bit out of the grill section. Next to the mounting tabs, just infront of the intake snorkel, only the width of the intake area on the snorkel and about an inch and a quarter deep. This is with a series 1 Futura grille tho (but the same can be done for all S1 low bonnets, not sure about XRs). I've checked my design template on all AU's except XR, and it will fit all, hence me wanting to make a few of them up and sell them. It will actually fit BA/BF, but this requires more extensive cutting of the radiator vent panel.
Previously:
Old 30-01-2009, 02:22 PM   #13
MGGT RAA
MGGT RAA's Avatar
I wouldnt know if they are any different, if i find anyone with a non XR ill give it a try and let ya know.I wasnt to keen on taking to my car with the hacksaw... sounds pretty well similiar to mine though. Yeah ive ahd a couple orders for them today ay haha
Old 30-01-2009, 02:35 PM   #14
broken_suave
For mine I used a jewellery saw (only thing I had that would do the trick) and then a dremel to smooth it out.
Previously:
Old 30-01-2009, 10:42 PM   #15
private9
www.TUFFCARPARTS.com
private9's Avatar
Wouldn't have any pics would you?
I wouldn't mind giving something like this a try.
Old 31-01-2009, 03:56 AM   #16
martymonsta79
MARTY (AU2 FUTURA)
Just going from memory there are two books about getting the most out of your 6cyl Falcons prob about 7/8 years old written by the guys at JMM telling you which intakes are best (EF had best flow I think) but JMM do a bolt on mode thats removes the restriction from the start of the intake pipe at the box and joins at the flexi rubber pipe for under $200 big ones an gives you instructions on how to increase your flow into the stock box, but i went with the 3" pacemaker c/c intake pipe and pod filter cause I like the noise.
hope this helps.
martymonsta79 is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2009, 04:51 PM   #17
Stav
Smile
Stav's Avatar
Good advice all ...
Old 31-01-2009, 07:33 PM   #18
broken_suave
Sorry Private,
At the moment, all I have is the cardboard template, and thats currently packed away in boxes as we're moving.
Once I have everything set up again, I'll put up some pics.
*EDIT* I just realised you meant the grille. I'll put some pics of that up once we're settled also.
Previously:
Old 31-01-2009, 09:28 PM   #19
FS5
here's a dodgy one i made
http://www.fordforums.com.au/showthread.php?t=81400
i already had the jmm pod one fitted
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17.
FS5 is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2009, 06:46 PM   #20
au11futura
ROCKING THE EL FUTURA
au11futura's Avatar
well this is the one ive got not done yet need the bigger intake pipe but should do it.
au11futura is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2009, 03:56 PM   #21
AU3XSR
First time Falconless
AU3XSR's Avatar
To all the ppl talking about the scoop, I suspect that this is what you are talking about???
I have the aluminium scoop, XR6T snorkel, Splitfire air filter, 3" intake pipe bell-mouthed into the middle of an EF airbox lid and BA upper intake piping fitted.
Can't remember if this really does anything from the stock setup as its been on the car for nearly a year...but for those worried about fuel consumption increases, I filled up the other day after doing 600km from a tank and the old girl returned 9.3L/100km from a combined cycle (2 weeks of daily use to the train station and back home and a couple of weekend highway stints), which I thought was pretty good
Am getting pacemakers fitted soon, so the setup may be more useful then...
AU3XSR is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2009, 07:06 PM   #22
MGGT RAA
MGGT RAA's Avatar
yeah a scoop not a snorkal...
Iv'e had mine on about a week and it definatly aint worse on fuel, havnt noticed a mega difference but it is slightly better fuel and pick-up wise.
Old 04-02-2009, 08:50 PM   #23
Dave_Obsession
I've seen some of these scoops on ebay now......they say you need to cut a portion of the grille out though - is this right??? Or can you get away with not cutting anything....
Old 05-02-2009, 11:38 AM   #24
broken_suave
You do need to cut out a small bit, as AU3XSR has done in the top pic. Its not visable once you close the bonnet, it just allows the flow of air from the grille area, up to the snorkel area.
Previously:
Old 05-02-2009, 11:47 AM   #25
rag top
rag top's Avatar
After a recent discussion with GK, I thought I'd try removing the stainless steel piping and go back to the standard piping. Not sure if it was the heat on the stainless pipe or the diameter but the ute now has a lot more torque down low. (tis LPG only, if that makes a difference).
I also have the XRT snorkel and a K&N filter.
rag top is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2009, 11:55 AM   #26
Whoosha
AU DIE HARD
Whoosha's Avatar
I know ware a box full of these are all ready made up .. from a previous Idea someone had :
PM me if you would like one
Originally Posted by Riksta
Old 06-02-2009, 01:32 PM   #27
DookaAU2
DookaAU2's Avatar
^^Cheers to Whoosha for the s**te load of airboxes for the forums, I think the main reasoning behind change the AU stock piping to 3" was because it went from 2.5" at the airbox inlet to 3" piping into the throttle anyway if I'm not mistaken
DookaAU2 is offline   Reply With Quote Multi-Quote with this Post
Old 06-02-2009, 04:53 PM   #28
Whoosha
AU DIE HARD
Whoosha's Avatar
Found 1/2 a dozen laying around, pressed ally looking at @$10 each + P&H Let me know if your interested
Old 07-02-2009, 01:44 AM   #29
rag top
rag top's Avatar
Hey Whoosha, I presume it uses the existing holes for the snorkle?
Old 07-02-2009, 08:50 PM   #30
private9
private9's Avatar
Picked one of these up from Whoosha today, looks great, thanks mate!
Ok, I'll preface the following question by admitting that yes, clearly I am dumb!
I went to fit the thing, and I've clearly forgotten how Whoosh showed me to fit it!
So, does it go like this, connected to the 2 snorkel screws:
Or, like this, under the grill?
