Morning all,
On my way to work this morning, I pressed my trip meter too see my average L/100km. I did then then went to go back round to distance to empty. As I did this the screen went real dodgey as did the climate control. Everything worked but the screen was being stupid! I pressed the off button and the change position button like suggested in another thread. All lights lit up but no change. Just went back to being brocken! What could this be and how do i fix it? Cheers, Matt.
Daily: AU Forte Wagon Project: AU Fairmont - Wants to be turbo The Family Car: 2009 G6E Turbo Future fun: 1968 Ford Galaxie 500 |
I will get a photo of it if its still doing it this arvo. Any ideas?
So when you reset all the digit's lighted up? Sounds like the unit may have just carked it, which i've never heard of them doing that wasn't fixable very the floor/off reset.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm. |
Yeah its playing up. Like it doesnt illuminate everything. Like say a 9 looks like a 1.. Its weird, and hard to explain.
When i pressed floor, and off everything lit up then it made a weird noise. Like an arial going up (99% sure it was the vents changing position but was loud and sounded bad). Then all the illuminated lights go off and it just goes back to being poo.. Then when i change vent position you can hear it again.. Im stuck for ideas..
![]() Join Date: Nov 2007
have you tried the old "ironing of the ribbon trick", when i got mine the display was pretty much non existant, i tried the old trick and mine is now like a new one.
Give us a sec and i will find the link......
Here tis:
-------------------------------------------------------------------------------- Quote: Originally Posted by Lil Monty Missing AU Fairmont/ Ghia Climate control digital segments? It's an easy fix!!! 1.0 Tools Required; 1.1 Phillips head and flat blade screw drivers 1.2 Cloths iron 1.3 Baking paper 2.0 Remove climate control unit from dash; 2.1 Removing clock surround, allowing access to retaining screw, remove screw, 2.2 Pull unit forward and to the left, unplugging 1 air sensor and 2 electrical plugs. 2.3 Unit should now slide right out 3.0 Dis-assemble control unit; 3.1 Depress and pull plastic retaining legs where appropriate 3.2 Slide unit out rear of casing. 4.0 Re-attach control ribbon 4.1 Pre-heat iron to sub steam temperature 4.2 Clean/ trim ribbon and contacts if required (do not use solvent as will destroy ribbon/ adherence) 4.3 Re-align ribbon with circuit contacts 4.4 Place baking paper on top or ribbon to stop ribbon melting onto iron 4.5 With moderate pressure, press iron onto ribbon and contacts 4.6 Check contacts/ test in car before refitting into casing. 5.0 Re-assemble in reverse order **This worked for me, ONLY to restore the display functions thou..hope it helps.!
Sounds like what mont has posted.
I'll just add in that when ribbon repairs like these, i personally like to add a good piece of foam in after it has been iron'd, using the foam to apply a small pressure pushing the contacts down, thus helping to avoid any later probs.
All Bran = Regular Member
If ironing the ribbon fails you can try this guy. Quite a few au members have had success with him
http://www.geocities.com/liquidxtal/index_ford.html |
![]() Thats basically what mine is doing!
Just slidin'
Slow down, your going OVER 2 K'S PER HOUR!!!
Its just the contacts on the back. Try belting it from the top, or do what mont5.0 said.
MD Mondeo - For the family
#11 | |||
#12 | ||
Started working when i got back in the car. Weird..
Might give this guy a call if it happens again.
not here much anymore
Sounds like its on its way out
RAM 1500
#14 | ||
Yeah.. Ah well thats life.
#15 | |||
I posted it down from Bris on the Monday and it arrived back on the Thursday. At the time it cost $70 + postage... bargain! |
#16 | ||
Formally FairmontPom
I dropped my unit at his house, and picked it up again 2 days later, and has worked for another 2 years without fault !
1998 XH Falcon V8 S Pack, white, couple of dents. Bogan project 2020 PX3 Ranger XLT 4x4, 10 speed BiTurbo, Tech Pack, Black wheel pack, HSP powered roller shutter, LED fogs, tailgate central locking and auto fold mirror upgrades. |
#17 | ||
is he not going to do the same thing as i posted above?- if so, have a crack yourself!- i know i would prefer the 150 in my pocket!
#18 | ||
Just another mock-up..
hey, i'm doing this at the moment... what makes the ribbon stick back on...? i've cleaned the contacts, am i supposed to cut the ribbon to make it stick back on or should i just re-attach it how it was...?
any help would be appreciated ASAP guys, the missus is starting to get upset...lol thanks heaps fellas...
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
#19 | ||
im sure theres supposed to be a type of adhesive which the iron re-melts somewhat...
good luck Kristo.. i gotta try this my self yet.. just to slack to do it lol
#20 | ||
You can do it if your careful buy using the same method and applying a low temp solder to the board, so that it actually solder's the connection when you heat it up.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm. Last edited by 5.0 ED; 22-11-2008 at 08:37 PM. |
#21 | ||
well... tried it... was in a rush... DON'T cut the ribbon to try and get better contact because it doesn't stick back down... i'm going to stick to the mechanical side of things from now on... not electrical...lol
#22 | ||
Yes don't ever cut the ribbon.
