Old 19-11-2008, 01:06 PM   #1
JoesAu
JoesAu's Avatar
Default Something New for the 4l
Well i dont know if these work but check it out, who gonna try it out?
http://cgi.ebay.com.au/ws/eBayISAPI....m=400006252883
JoesAu is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2008, 01:34 PM   #2
ten[A]cio[U]s
ten[A]cio[U]s's Avatar
Kinda makes sense in theory. Would want to hear of success stories before i try that sort of thing though..
Daily: AU Forte Wagon
Project: AU Fairmont - Wants to be turbo
The Family Car: 2009 G6E Turbo
Future fun: 1968 Ford Galaxie 500
ten[A]cio[U]s is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2008, 01:46 PM   #3
AndrewR_AUII
AndrewR_AUII's Avatar
Should be pretty easy to test... I THINK manifold air temp is available via the OBD port....
However, I wouldnt expect much of a difference..
AndrewR_AUII is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2008, 01:55 PM   #4
Allen
You win again, gravity!!!
Allen's Avatar
The spacers have been around for ages for the 5.0 engines, and even older engines would apparently benifit from a spacer in between the intake manifold flange and the carby.
No reason why it shoudn't work on a 4.0, but the gains would be minimal at best.
1994 ED Ghia
SOON TO BE A TRACK CAR
Allen is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2008, 02:06 PM   #5
superroo
You can't stop the signal
superroo's Avatar
It also has the effect of making both runners longer.
What this means is the bottom end should pick up some gains, but the top end will drop off.
This was raised in the B-sereis section not long ago. Don't know how it went though.
Old 19-11-2008, 03:52 PM   #6
poolkeeper
Its Resonating!
poolkeeper's Avatar
Seems ok, looks interesting
poolkeeper is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2008, 05:49 PM   #7
poolkeeper
Its Resonating!
poolkeeper's Avatar
Had a look on fordmods, seem to be a bit on this topic, heat soak etc
And as mentioned, it will pull on the throttle body cable- being spaced out 12mm
