Old 10-08-2008, 03:16 PM   #1
italianfairmont
OFF ITS HEAD
italianfairmont's Avatar
Default FS: (SA) Wrecking 1990 Ford Kf S Laser With Tx3 Turbo Conversion, Name your part.
Hi all my brother is wrecking his 1990 FORD KF S 4DR LASER which has a TX3 TURBO motor in it.
Name a part that you may or will need and i will get back to you on a price.
Everything on the car is good except the dash as it has a crack in it.
The only extra things that he has that are not standard and are For Sale are....
-- Used Xtreme Button clutch to suit 1.8L SOHC gearbox.
-- Altezza clear front Indicators.
-- Red and Silver Isotta steering wheel and Boss kit to suit Ford Laser.
-- Near brand new Bosch yellow 8mm leads for KF Laser.
-- Turbosmart Manual adjustable Boost Controller.
-- Turbosmart Blow Off Valve (basically still brand new).
-- Four Proton 4 stud GTI wheels and tyres 16 inch. **SOLD**
-- Steel Air Intake Piping for TX3 TURBO motor with spot for Blow Off Valve, which connects to a standard TX3 intercooler.
-- KF 1.8L 5SPD SOHC gearbox.
-- 4" Xforce cannon with 5" barrel.
-- 3" Chrome Dump exhaust tip.
-- Four steel rims (4 stud) with tyres, suit ford, mazda, lancer etc.
I almost forgot to mention he has TWO Engines FOR SALE. They are....
-- KF 1.8L SOHC laser engine with blue rocket cover.
-- TX3 TURBO motor 1.8L DOHC with Mazda rocket cover.
Then there is also the parts that you usually find on a four door KF Laser.
cheers
ITALIANFAIRMONT
FORD EF FAIRMONT, ARGON SILVER
*EXTRACTORS, HI-FLOW CAT, 2.5 INCH ZORST WITH RESI TWIN TIP
*FORD FPV GT-P 18" WHEELS*
*KYB LOWERED SHOCKERS*
*KING SPRING SUPERLOWS*
*POWERCHIP, (BY K.P.M. MOTORSPORT*
*SLOTTED BRAKE DISCS*
*FULL APLINE STEREO*
*MONSTER FLOW POD FILTER
italianfairmont is offline   Reply With Quote Multi-Quote with this Post
Old 10-08-2008, 08:13 PM   #2
ebxr8240
Performance moderator
ebxr8240's Avatar
How many threads and posts are you going to post this in ??
Daily driver GTE FG..
Old 20-01-2009, 03:49 PM   #3
msabell
hi have you still got parts from the laser??
msabell is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2009, 01:30 AM   #4
Force_6
What Traction?
Might be a bit late but...
what colour is the TX3?
and does he still have the TX3 front bumper with the lip..
Force_6 is offline   Reply With Quote Multi-Quote with this Post
