04-06-2008, 07:03 PM | #1 | ||
Hi all,
Just after some help my car has developed a slight knocking noise in the front mainly when turning or when straightening the wheel. Any help greatly appreciated. Thanks Lynda
AU3 XR8 220kw King Super Lows, 19' Wheels, 3' single system exhaust |
04-06-2008, 07:14 PM | #2 | ||
Sounds like a dry creaking noise.
04-06-2008, 10:15 PM | #3 | ||
Sales Representative
Rubbers... possibly A-arm... but maybe tie rod end...
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! |
04-06-2008, 11:27 PM | #4 | ||
Smile
Tie rod,ball joint or cactus shock absorber.Might even be low worn brake pads..cheers.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
04-06-2008, 11:41 PM | #5 | ||
Critical Thinker
Just a stab here, but I reckon it could be lower control arm bushes and/or 'D' bushes on the sway bar.
Get a $14 28 point safety check from pedders, and they will give you a report of the condition of your entire suspension system with quotes on cost to repair. You dont have to get it repaired by them of course, but the report is handy. Let us know what the problem was if you find out.
05-06-2008, 02:45 AM | #6 | ||
If its a creeking noise that occurs when turning at low speed, ie 0- 20 kmph it a very good chance its the Steering Rack bolts are slightly loose, as in they need a nip up.Mine made this noise for a while, when I went to get a wheel alignment done I asked him to check it out for me, so 1/16th of a turn of the bolt and it's gone and did'nt cost me a cent because I did'nt get the wheel alighnment done as I was told a new steering rack was required sooner or later because there was a bit of oil leaking from the boots, so I'll wait until I get the new rack before getting a wheel alignment.
Let us know how it goes, pretty sure this is your remedy.
Losing my patients with unfinished threads Did the ideas people helped you with work or not! |
05-06-2008, 09:17 AM | #7 | |||
Smile
05-06-2008, 09:48 AM | #8 | |||
Thanks for the advise guys will take to mechanic and get him to check it out.
05-06-2008, 07:34 PM | #9 | ||
Boost Addict
noone mentioned wheel bearing yet?
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO Can't live with it, can't live without it! |
05-06-2008, 08:22 PM | #10 | |||
Back to Le Frenchy
I'm going to go with a lower ball joint. They are an issue on nearly every Falcon ever made and the creaking sound is synonymous with it. Mine made the same noise and turned out to be ball joints.
05-06-2008, 10:51 PM | #11 | ||
Hubby had a good look underneath it tonight when you turn wheel makes a creaking sound but when we put it up on the Jack it didn't make it.So obvioulsy only when there's weight on the wheels. Going to take it to Mechanic in morning.
Thanks for your input guys. I'll let the winner know tomorrow.lol
06-06-2008, 02:54 AM | #12 | |||
06-06-2008, 10:23 PM | #13 | ||
XR6T 400kw(well one day!)
I got a $14 safety check with pedders and thought it was well worth it.
They told me what my knock was and also told me what I should get replaced within 6 months to a year. There was no pressure to get the work done there either.
If it Vibrates, rattles, squeaks or knocks - then it must be a Territory |
06-06-2008, 10:36 PM | #14 | ||
Wanting a sprint!
So what did the mechanic have to say Lynda?
On track for mint turbo falcon |
07-06-2008, 12:15 AM | #15 | |||
07-06-2008, 10:02 AM | #16 | ||
Sly like a G6
The dry creaking noise I had in mine when turning at low speeds turned out to be a seized upper ball joint. It wasn't visible with the car jacked up... only showed up when I replaced the 2 uppers while fitting a BA suspension and brakes. But there are a number of possible causes.
I vote for the Pedders $14 safety check too.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
07-06-2008, 06:11 PM | #17 | ||
It can be a number of things ... and pretty much the main culprits have been mentioned.
I agree with the safety check ... make sure the suspension place as the proper drive-on tester as well. Dry creaking noise could also be air in the power-steering system ... it might not have been bled properly when the rack was replaced (as you mentioned it had been) .. this could be another cause ... it only does this when turning the wheel at standstill or low speeds and with load on it (ie : not up on a hoist).
08-06-2008, 10:36 AM | #18 | ||
the noise is an excuss to sell it and get a fg turbo
i won. |
