Formerly MR BAXR6t
hey all
Just wanted to know how easy it is to change the intermediate shaft? Steering is loose and isnt the safest thing when drining down the motorway. Looks pretty staight forward job, but would like to know from ppl with expierience. Also ive heard they are only available form Ford parts and no aftermarket ones? Is this correct? If so wat would i be looking at price wise? Cheers guys Frank
Current car 94 ED Fairmont 5L in Burgundy Fords ive owned- 2010 FG XR6 5 speed auto in Mystic 81 XD S-Pac 302c 4sp manual 78 Yellow TE Cortina Wagon 4.1L 92 Green EB Fairmont GT replica 01 Black AU XR8 II Manual 04 Rapid BAII XR6T 220rwkw 04 Mandarin BA XR6T 247rwkw 07 BF II XR6T 385rwkw 1980 ZJ Fairlane 302c |
tufLTD
Are you talking about the shaft between the column & steering rack?
If so, it takes about 10 mins to change, just 2 10mm headed bolts & slide it off. It's a Ford only part, about $180. |
#3 | |||
Formerly MR BAXR6t
cheers
tufLTD
$420!!! That's a nice little earner for someone.
Formerly MR BAXR6t
Yea ive found they over charge alot! ill get that steering dont tomorrow
cheers
![]() Join Date: Jan 2005
Easy as. I got a replacement one for mine from the wreckers for $70. It's the bearing in the cup part that goes, so just check to make sure there' no play/movement.
Not to remove and fit: 1. undo both 10mm bolts (one at rack, and one at top uni joint near firewall). 2. slide shaft up towards firewall. 3. slide cup end off rack 4. slide top end back towards the ground, and you should end up with one intermediate shaft in your hand. 5. Refitting is the reversal of removal (start at step 4 through to step 1). Note that the shafts have one large spline piece, so the new intermediate shaft can only go on one way, and it can be fiddly to fit, but patience (and a cold engine) is the key.
Yeah the hot exhaust can be a problem.
#8 | |||
Formerly MR BAXR6t
i just found out that ford want 290 buks because my car is a v8. What is the difference between the 6 & 8 shaft???
cheers frank
#10 | |||
Have you tried the wreckers at all?
#11 | |||
You can't stop the signal
When i had my rack changed i was asked it was a 6 or an 8, so they probably are different.
Check the parts data on here for answers. Cheers
#12 | ||
Formerly MR BAXR6t
I checked a couple of wreckers. they werent sure?? my shaft now has the heat sheild round it, dunno if that helps at all..
cheers
Formerly MR BAXR6t
Also if anyone has one lying a round please let me know. ive called around and the v8 shaft seems rare.
cheers
#14 | ||
The v8 ones do have the heat shield wrapped around them as the shaft goes through between the pipes so i dare say that would be the difference.
#15 | |||
Formerly MR BAXR6t
#16 | ||
![]() Join Date: Dec 2006
Make sure you don't turn the steering wheel while the shaft is off
I usually tie the steering wheel to the handbrake or something |
#17 | ||
so did anyone work out if there was infact a difference between the i6 and v8 shafts?
#18 | ||
Well ... I got mine through Darren at FTG ... he was able to source one for me from one of the wrecks there ... was cheap as well.
You best bet is to ask him.
#19 | ||
this is from the parts database,
Part # Description Unit Price ER 3C662 A SHAFT STEERING COL, LOWER, (-) XR8, ALL 6 CYL ENGINES $185.25 ER 3C662 D SHAFT STEERING COL, LOWER, (4 DOOR SED (-)S/XR6 5.0 V8 OR FAIRLANE/LTD 5.0 V8 OR 4 DOOR WAGON FORTE/FAIRMONT 5.0 V8) $292.50 i would assume there is some difference, looking at that. what the difference is, i'm not sure... |
#20 | ||
I think it means the top one is minus the V8 versions (-) ... and the bottom one is minus the S/XR6 models.
#21 | ||
Tickford Equiped
My steering has been feeling a little strange lately on and off. How do i tell if its worn?? If it is worn, should I be able to feel play in the shaft if i riggle it around, or will it always have a little movement?
Genuine Tickford Equiped 1998 AU Fairmont Mods: ....... Dash mat & Air Freshener, does that count as a mod?????? Sports Exahust, Tickford Intake Snorkle, K&N Filter, NGK Plugs, Top Gun Leads TS50 Front Bar with Fog lights, TS50 Rear Bar. Injected LPG System, |
#22 | |||
Formerly MR BAXR6t
Easiest way is physically grab the sharft and wriggle it round, ull soon get ur answer. Cheers
#23 | ||
If you have any "play" in the steering wheel, then chances are it is the intermediate shaft.
#24 | |||
Once you get the stuffed intermediate shaft out and look at it ... you will immediately realise who stuffed it really is ... mine had a decent amount of play where the pin goes through.
#25 | |||
Was quoted $440 for new one! You'd think they'd put both unis on the intermediate shaft. :evil3: |
#26 | |||
![]() anyway as everyone else has said its a pretty straightforward job and has made an enormous difference to the steering. feels like a new car!! I don't know how many they would've made but if anyone needs one maybe there will be stock now for a while... |
