Old 12-02-2008, 08:23 PM   #1
1 dvs 4d
1 dvs 4d's Avatar
Default V6 Tc Cortina's
I have read somewhere that Ford brought some TC's in from South Africa with the 3lt v6 in them for evaluation prior to launching the TC 6 cylinder. I do remember one at Summernats a while back with NSW plates VEE 600 but other than that nothing.
Does anyone have any info???
ED XR6 Polynesian Green JMM DEV 3HL/5 kit *sold*
EL 5LTR Ghia Argon Silver slammed cruiser *sold*
BA UTE daily workhorse
ED XR6 Cobalt Blue Project Car
1 dvs 4d is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2008, 08:26 PM   #2
wodahs
wodahs's Avatar
dont know about that but i do know that an older capri came with a v6 maybe it was the same motor
if some one can shed some light ?
yes still (as money n time permit) doing the
rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually
just remember don't be afraid to try something new.
Remember, amateurs built the Ark...Professionals built the Titanic!
I have taken up meditation... at least it's better than sitting around doing nothing !!
wodahs is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2008, 02:55 PM   #3
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
I remember reading about one, not sure if it was a private import or not though. You are right wodahs, it would have been the Essex V6, ahthough in Germany they would have been built with the Cologne V6 as well.
Old 13-02-2008, 07:54 PM   #4
benny_mac
benny_mac's Avatar
I know they have granada's(which are basically british cortina's) which had the colonge 2.8 v6. maybe one was imported.
New Project: 1980 MK2 Escort Panel Van, 2lt, auto
Soon to be painted running a 4.0ltr v6
See the build here
http://www.fordforums.com.au/showthread.php?t=11388068
You Have Freedom of Speech Just Choose to Remain Silent
benny_mac is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2008, 09:07 AM   #5
whooligan
whooligan's Avatar
The South Africans used both the 3.0lt and 2.5lt V6 Essex engines in their TC Cortinas. There was one in a street machine years ago...purple with pink rocker covers (very 70's)
The cologne V6 is a very different motor to the Essex forund in Capris, but some later TE/TF (Mk4&5) Cortinas had 2.3lt colognes fitted with C3 autos in Europe....Mainly wagons.
The V6 Essex was available as a conversion through a UK tuner named Jeff Uren. They were badged as a "Savage Cortina." He also did 2.0lt Escorts in the early 70's a few years before Ford got around to it in 1974.
Granadas were sold along side the Cortinas in Britain. They were in-btwen the Cortina and Falcon in terms of size, although the Falcon was never sold in Europe.
whooligan is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2008, 10:11 PM   #6
1 dvs 4d
1 dvs 4d's Avatar
Thanks for the info Guys. If I can track one of these or a straight 4.1 litre TE down I'll be a happy man
Old 19-02-2008, 02:42 PM   #7
Jim5_0
I remember seeing that TC V6 in a Street machine magazine a few years ago.
The bonnet differed from any other Cortina that I have seen in that the raised centre section is a lot higher than a standard bonnet. Very much in the same way that all Aussie TE and TF Cortina's have a higher centre section to their bonnet than their equivalent MK4 and MK5 brethren thus not needing the TC/TD bulge to clear the air cleaner on the 6 cylinder versions.
Jim5_0 is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2008, 12:42 PM   #8
ayamisu
There was also a mk2 cortina with a v6 essex motor in it.
the tc td cortinas also had the same motor as well as imports...
I have an escort fitted witha v6 essex in it, it is a tight fit but you should be able to make it fit in the corty alot easier than i got it in the eski.
ayamisu is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2008, 06:58 PM   #9
1 dvs 4d
1 dvs 4d's Avatar
The mk2's are the Cortina Savage aren't they.
If anyone has any info on the South African Cortina's could they drop me a line
Cheers guys
Old 21-02-2008, 08:41 PM   #10
PIG250
PIG250's Avatar
They also have a round fuel filler, whereas we have rectangle ones.
PIG250 is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2008, 10:17 PM   #11
ayamisu
there is a cortina manual not sure which one but is does go into detail about the SAVAGE.
i did read a copie i borrowed about 2 yrs ago off a mate in the car club but he has since moved on.
Old 22-02-2008, 10:20 PM   #12
ayamisu
Also forgot to say the raised section on the cortina mentioned i think is from choice and not a factory or needed option as my eski all i have is my airfilter out of the bonnet and only because i chose to and the rest is under bonnet and im running a holley with a high rise manifold too
Old 23-02-2008, 10:57 AM   #13
1 dvs 4d
1 dvs 4d's Avatar
The TC and TD Cortina's had the bulge in the bonnet to clear the 6 cylinder rocker cover and air cleaner. The four still had the flat bonnet. All aussie TE and TF's had the raised centre of the bonnet regardless of engine capacity. I'll have to watch my dvd again to see if the english cars had it or not
The savage was a limited run of mk2's fitted with v69's by an english tuner again i'll have to watch my dvd again to get the full story.
If anyone knows the whereabouts of the pastel blue VEE 600 NSW rego'd TC v6 that was at Summernats in 92. Could they let me know
Old 27-02-2008, 10:43 AM   #14
Jim5_0
Originally Posted by 1 dvs 4d
All aussie TE and TF's had the raised centre of the bonnet regardless of engine capacity. I'll have to watch my dvd again to see if the English cars had it or not
The English ones had the raised centre to the bonnet but it's nowhere near as high as it is on Aussie TE/TF's. The MK4 and MK5 bonnet also has a slight line down the centre of the bonnet running front to back whereas the TE/TF does not. You have to catch this in the right light to notice it though as it is very slight.
Old 27-02-2008, 06:20 PM   #15
fmc351
let it burn
I recall reading somewhere here that the Fairmont GXL was available in the UK. There was a pic of one with UK plates too.
Old 27-02-2008, 08:13 PM   #16
bingoTE50
Steve
bingoTE50's Avatar
There was a SA one in Campbelltown in Sydney about 6 years ago.From memory it was a blue TE shape . The guy had it for sale at a Peter Warren Ford Day in about 2002 .. All I can remember really...
bingoTE50 is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2008, 09:06 PM   #17
Jim5_0
Yep Fairmonts and Valiant Regals were sold in the UK in small numbers. Trouble is they cost at least as much as a Jaguar when new which would explain the small numbers.
Old 28-02-2008, 10:39 PM   #18
1 dvs 4d
1 dvs 4d's Avatar
These cars are hard to come by, I recall the SA one back in 02 as well, but i haven't been able to get even a pic of one to start my search.
